Hello all, I have an 89 gt vert. I bought a trick flow stage one cam, and a 76mm c&l maf with 24# injectors, installed it all and now the car will not hardly idle if I come to a fast stop, it will reve up two or three times and die. I reset my tps to .95 at idle and reset my idle. Please help. Thanks for all of your time.
, sorry, mine was color coded. Also, when I had my lunati cam in my old 87gt, I could not get my car idle at all, so we put an idle spacer( don't know if that is the correct name), it looked like a spacer that went on the iac, and had a screw you could adjust. It was the only way I could get that car to idle, may wanna look into that if everything else checks out. Might also want to check codes as well.
