I need some space
  • Thread starter Thread starter kidtaurus
  • Start date Start date Jul 7, 2004
kidtaurus
221
Athens, Ga.
Jul 7, 2004
  • Jul 7, 2004
I recently purchased a Taurus E-fan and when I went to install it was touching the pulleys. Is there any way to make room for the fan. Mind you I do not have a garage, or a convenient electrical outlet nearby.
DarkBuddha
2,215
Seattle & Tampa
Jul 7, 2004
  • Jul 7, 2004
Don't get me started about not having a garage... I empathize... As for the fan fitment... first, see if you can offset it by an inch or two to get the motor way from the pulleys. This is what I had to do with mine... Sure, it ain't centered anymore, but who cares. Or you can try to trim the "shroud" back a bit (I don't know that fan at all, so I don't know if there space to trim) using a dremel. You should be able to do this in your house/condo/apartment as long as you keep checking to make sure the fan doesn't extend past the shroud (into where the radiator would be). The last option is probably to get a slimmer fan... mine is right at 3.75", and I had to offset it by an inch so it wouldn't interfere. It's rated at 2700CFM or something like that, and I can tell you, it does a heck of a job. I think it was well under $100.
Hope this helps.
kidtaurus
221
Athens, Ga.
Jul 7, 2004
  • Jul 7, 2004
What fan did you get? I am gonna try to see if I can trim and offset it
DarkBuddha
2,215
Seattle & Tampa
Jul 7, 2004
  • Jul 7, 2004
It looks like its gone up in price a bit since I bought it, but still under $100... 2700 CFM electric fan . It says it's 4.5" deep, so I might be wrong when I said 3.75". BTW, they've got other fans, even a 3100CFM unit... other fans .
Hopefully you can keep the Taurus fan. They're supposed to be good fans, and I'll bet it was way cheaper than buying new. Good luck.
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
F
AC Compressor Power & Contour Fans
  • Fri Guy
  • Aug 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 15, 2026
BoostedRed89gt
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
