1980 Mustang w/68 302 points dizzy. Everything was working fine on Tuesday night. Wednesday afternoon I go to start it and it turns over with no fire. I'm in the middle of a dash swap finished all the wiring on Tue. night and everything was working fine. I put a charger on the battery cuz I was turning lights on and off alot during wiring. Well Wednesday morning I got the key out of it and realized I left the key on all night with the charger hooked to the battery. Don't know if that would have anything to do with it. I don't think so the battery never died.
Well anyways Wed. afternoon I traced it down to a blown fuse. I threw another in and pop right when I turn the key on. So I pulled the wires off the coil and put another fuse in. Turned key on and fuse was fine. I hooked the + up then the - for the tach. Still the fuse was ok. Then hooked the - from the dizzy. Instantly the fuse blew.
I traced the wire from the coil to the dizzy and it looked fine and tested it with a multimeter and the wire was fine. I looked in the dizzy to see if anything by the points were touching that are not supposed to and that was fine. So I started to follow the + wire. Followed that through the firewall and it splits through a harness. One to the fuse box the other to the cluster. Since I just was repinning the cluster I double and triple checked the wires all fine and all hold power fine. Also none were crossed or bare or anything like that.
So I swapped coils and the fuse was fine. Tried to start and still no ****ing spark. WTF! so I look at the coil and that thing was so hot I could hardly touch it. As fast as I could I pulled the wires off.
The only thing I can think of is I have a short somewhere by the cluster. But it worked fine Tue. at midnight and 14 hours later it don't and no one has touched it at all.
Thanks and please help I'm getting sick of wiring.
O forgot to add points were replaced 2 weeks ago.
