Hey guys. I've been slowly adding mods to my car, recently a full MSD ignition setup and 3G alt. I want to make 300 RWHP, 300 RWTQ by the end of the summer with what I've got. Planned additions are a Mk VIII electric fan, A/C delete, 75mm Pro M MAF, 24# injectors, and a 70mm TB+EGR spacer. I'm hoping that by uncorking the airflow into the intake with the bigger TB and MAF, I'll pick up some power that I should have in there. The 24s are just to prevent top end starvation. I heard that an electric water pump can free up close to 10 HP by removing drag on the waterpump with the removal of the clutch fan. Any other little tips I can do to hit that magic 300?
Here's my mod list:
Ford OEM: MAF Conversion, Short Shifted 5-spd, '97 Explorer Intake, Idle Adjuster Plate, SN95 5 lug/ disc brake conversion, 3G Alternator, Mk VIII Electric Fan, 19 lb injectors, Smog pump delete.
FRPP:GT40 "P" Heads, E303 Camshaft, 1 5/8" Shorty "P" Headers, 1.72 Roller Rockers, Aluminum Driveshaft, Heavy Duty Clutch, 3.73 Rear Gears, Hood Pins, 1" Phenolic Intake Spacer, A/C Delete Kit.
MAC: Cold Air Intake, ProChamber, Flowpath LX Catback, Underdrive Pullies.
BBK: Progressive Rate Springs, Subframes.
Walbro: 255 LPH Fuel Pump.
Crane Cams: Adjustable Fuel Pressure Regulator.
MSD: 6AL, TFI Blaster Coil, 8.5mm Super Conductor Wires, Distributor cap, Rotor
Hurst: T Handle Shifter Knob
UPR: Extreme Firewall Adjuster
Summit: Adjustable Brake Proportioning Valve, Aluminum Clutch Quadrant
Age Classic Design: Clear Corner Lights, "Street Heat" Cowl
Cervini's: Cobra Rear Bumper, Cobra R Hood, Saleen Wing, Stalker Front Bumper
RotorWorks: Slotted/ Cross Drilled Rotors.
AutoMeter: 5" Phantom Tachometer w/ Shift Light, Oil Temp Gauge, Oil Pressure Gauge, Tach Pod.
FatRodder: Flame Milled Chrome Tall Valve Covers
ROH: 17x8" White Snypers
Sumitomo: 4TR 245/45/ZR17 Tires
Here's my mod list:
