Injector Help!
gcwh02
515
pottstown, PA
I'm putting in the new engine this week and debating on whether to get 30 or 36 lb injectors. Its all in the sig, 12:1 comp. 350 stroker. I hear that 30's will be more suitable for the street and it is a street car seeing some track time. But I have a feeling that I will not be getting enough fuel spinning high rpms. Any help will be appreciated, thanks.
I woudl say 36# inj depending on the total combo, rpm range and expected power. We've made over 430RWHP with a 30# inj when using a tuner so we can adjust all the fuel parameters.
Are you using a stock EEC?
Injector HP ratings: divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle. These ratings are for naturally aspirated engines. See my comments on pressurized induction in the paragraphs following this one.
Example:
19/.5 = 38, 38 x 8 = 304
24/.5 = 48, 48 x 8 = 384
30/.5 = 60, 60 x 8 = 480
The preferred duty cycle is about 85% maximum, so for a safety factor mulitply the final figure times .85.
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
I'd listen to what Rick says and go 36's. But you didn't even come close to listing enough info for anybody to help you.
You have a full point more compression than me and it sounds like you are spinning higher than me since you said high rpm's. I run 30's fwiw.
