  • SN95 V6 Mustang Tech
instrument clusters help!
  • Thread starter Thread starter yellow_stang
  • Start date Start date Nov 22, 2004
yellow_stang
  • Nov 22, 2004
Alright I need some help here, my odometer on my instrument cluster quit working and I took it to ford and asked what was wrong with it and after 3 hours and 40 bucks (basturds) they told me it was shot, i was pissed and left cuz it cost me 40 bucks... Anyway, I need an instrument cluster that will work for a 1998 v6 3.8, 120 mph, I need the mileage to be under 90 thousand, if anyone has one.
Another question I have is will a v6 1999 instrument cluster (with the digital odometer) work for my 98? What years can I get an instrument cluster from that that will work in my 98? I am guessing 94-98 v6 3.8 right? Please write back and anything will help, Thanx!
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Nov 22, 2004
  • Nov 22, 2004
It could possibly be just a burnt out fuse under the dash!
Have Ford check it out anyway! Welcome to Stangnet
R
raph130
517
  • Nov 22, 2004
yellow_stang
  • Nov 22, 2004
reply
Well everything works but the odometer and the one next to it (the travel odometer that shows like trips that is resetable), and the guys at ford told me I need a new instrument cluster, I guess they checked the fuses? The other gauges work fine and the speed and rmp meters work fine too, its just the odometer... Let me know if there is anything I can try or do. Thanx!
So does a 99 cluster work for the a 98 model?
yellow_stang
  • Nov 22, 2004
i switched out the fuses they werent problem anything else I could try?
232_slowness
74
Barksdale AFB
Nov 22, 2004
  • Nov 22, 2004
all i can think of is to replace it, i'm not sure how the odometer works on your car. Replaement shouldn't be too hard or too expensive, but you know how it goes, so don't take my word for it. For example a center air vent nozzle costs $75 from ford... lol
yellow_stang
  • Nov 22, 2004
If i find an instrument cluster off another 1998 v6 3.8 and replace mine with it should it work if that was the problem or are the computers different for each car? Btw I have taken the cluster out, it isn't difficult or anything its just I am stupped at what to do....
yellow_stang
  • Nov 23, 2004
can someone plez help me i am stuck????
98CobraClone
592
Ripley, Ohio
Nov 24, 2004
  • Nov 24, 2004
the clusters are relatively easy to change out. I don't think there is a problem with your computer if you change em out, but the 94-98 models use a mechanical odometer. A 99+ wouldn't work unless you get the necessary wiring, etc (i think)
When I had my gauges out, it's all a simple disassembly and install.
98stangv8
1,036
fayetteville, nc
Nov 24, 2004
#10
  • Nov 24, 2004
  • #10
the newer ones won't work...just buy one from your year on ebay and plug it back in..that is all you need to do..and it will work fine...assuming the one you buy also works..
yellow_stang
#11
  • Nov 24, 2004
  • #11
Thanx a lot thats all I needed to know!
L
Interior and Upholstery Instrument Cluster 1983 Mustang
  • loganatorspace
  • Jun 14, 2025
Fox 5.0 Mustang Tech Jun 19, 2025
Rcdgl
R
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
T
2003 GT cluster issue
  • Timothys gourmet
  • Aug 26, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 28, 2025
Mustang5L5
Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
2000ElectricGreen
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
