bump ur timing till your car just starts to ping, then step it back a degree.
thats how i've been told.
intake will hold oil (i think i read in the dips around the ports)... make an oil seperator, just read an article myself on here bout that.
oil seperator:
24" + 16" 3/8 fuel line
seperator from walmart
(two fittings for seperator)
1/4 male goes into seperator, and 3/8 goes away for line attachment
then read up on an article or two about it,
also, i believe its been said on here there's a break in period for gears?? am i right guys?
also, since you've been messing around the maf... clean ur air filter, then take out the maf and spray some contact electical cleaner on it and make sure it's clean, but don't touch it. u'll notice a lil throttle response if it was dirty.
if you have a KN filter, DO NOT OVER OIL IT...it blows back onto ur MAF, then you just cleaned it for no reason.
IF you changed ur TB... make sure ur TPS is set right, theres articles about that, but i think it's 0.97 v ...i forget tho
u said you did an intake swap i believe... make sure u torque the bolts properly and in the right order to insure proper seal.
pull a plug and see how it looks, and if nothing else change ur plugs wires, cap n rotor, while ur under there. (don't use crappy wires or plugs or ur wasting ur time)
Lastly for now, i think after an intake swap it's wise to change the oil and over the next few days check for coolant in there.
p.s. while ur under there just go ahead and order a crate engine and make er' a 347, and put a nice little blower on in and swap engines
k, im done! haha
