Zero Signal
never looked into this route, but don't some go with different rockers (1.7 or whatever) to get some of the impact of a cam swap (without all of the work). But still I think that comes after intake, TB etc.
Our heads can't flow worth crap with more than stock lift, so upping the rockers ratio won't do much for you. If it's lower valvetrain friction you want, it MIGHT help, but not nearly worth $180+
I would have said gears but since you already have them, the intake is a no brainer as the next biggest mod.
) I will be getting a 75mm unit. My philosophy is to match the parts. Also, my philosophy is that trick flow inc. knows more about engine modification then some guy on a forum, and if they want a 75mm TB, then damnit, they're gonna get one!
