Interesting Starting Issues, please help
ebelizard
30
After searching the forum, I havent been able to find out exactly what the problem is...
For some reason I have to spray engine starter fluid into the carb in order to get it to start, and then it idles rough until the engine warms up. After it warms up, it will fire up no problem.
I've adjusted the carb to run at 1k rpm, and a little on the leaner side for economical driving. When starting up, it still backfires a little, but not much.
Anyone have any suggestions?
dont know what you are running but i had a similar problem with my 66 200 I6 and finally found out that the choke used a small copper or brass tube that connected to the exhaust manifold inorder to operate properly, and i had my carb adjusted all wrong. once i fixed those two issues it would start perfect no mater weather or anything. like i said dont know what you have or anything but that was what fixed mine
i have a Edelbrock 1406 Performer Series carb, dont know what exactly your talking about though. I have a 302, with a AT. All vacume lines seem to be plugged or properly installed...
Sounds like a choke issue to me. I had very similar symptoms with my 302 just the other day. Turned out (my fault) that when I took off the electric choke cap and tried to reinstall it, I warped the "spring" inside the cap. I threw on the other cap I had and adjusted it properly and the car fired up immediately. Is yours an electric choke?
ebelizard i was referring basically the same thing pyroman was talkin about, the choke was malfunctioning in some maner and that was causing a similar situation to what you have. although my application was different than yours the problem may still be the same... check the choke mechanism and see what that yeilds...
If you choke it too much it will not run properly. If it does not have enough choke it will not run properly when cold.
I get mine started with the (manual) choke off and a lot of accelerator pumping. Once I get it started I adjust the choke until I get it in the optimal place. As the motor warms I slowly back it off.
My cold starting procedure is similar to 68RCodeConv.
Cold Start without pulling the choke. Just pumping the gas pedal 2-3times, waiting 2-3 seconds. Starting with the gaspedal pushed ~1/4 way down.
The engine starts, then i keep her alive the next ~10 seconds with the gas pedal. After that time the egine runs roughly on her own and after a minute warmup the idle turns smooth. I never need the choke, but also i only drive the car in warm months. No winter driving...
When i try to start the engine with the choke pulled or half pulled the result is nothing, no starting! So i always start without choke.
My Setup is: 289, 600 Holley Doublepumper, manual choke and transmission
