Intermittent Electrical Problem - Need Help!
67coupe
619
326
83
Huntsville, AL
Today on the way home from work. I noticed my electric fan was not working. I then noticed my HVAC blower was not working. NOTE: The "key on" wire for the RELAY for my electric fan is piggy-backed on this circiut at the fuse block. Checked fuse, it was okay. When I turned the key to the on position, everything worked.
A few minutes later, it all came back. Same symptoms as above. I also noticed my turn signals were not working. These are on different fuses. Checked the turn signal fuse, its also okay.
Here's the kicker. Once I got home, I went inside to change cloths. When I went to troubleshoot the problem, everything was working again.
I'm kinda at a lose on this one and was hoping some of you guys could get me started in the right direction.
Thanks.
  • Sponsors(?)
67coupe
619
326
83
Huntsville, AL
Yeah. Just finished searching myself. The ignition switch popped up immediately. I guess having two different fuses act up really threw me off.
Thanks for the help!!!
