is anyone running sn95 rearend under fox body
if any one has a reply what i am trying to find out is if 03 cobra wheels will fit under my fox vert with a sn95 rear if anyone knows or is running this combo please leave reply with details.i have to go to the doctor and will return around 12:00 to check.thanks god speed
fox racer said:
Correct me if im wrong, but arent the 87-93 housings the same as 94-94? only the axles and brake setups are different?
I did the swap several years ago, but I do believe that is correct.
I have a 95 rear end with sn95 wheels. I should have shortened the axles about .100" or so to help fender clearance with the 275s. I have a good .25" clearance with the quad shocks (yes they are still there). I did have to hammer the outer fender lips a bit. If the budget allows a Panhard bar will help keep the rear from sliding common to the body.
The swap does work. But I am not sure what I did will provide the best tire clearance with bigger tires.
jason
Housings are the same from 86-98. Only the brakes are different and will interchange.
99-04 has a wider housing. Brake setup is the same but they also use longer axle shafts
For an 87-92 you'll need the following motorsport parts
Center e-brake cable m-2810-a
Rear ebrake cabeles m-2809-a X 2
For a '93, substitute the two rear cables for
93 Cobra e-brake cables.
The parking brake handle just needs a tiny spot weld to lock the adjustment pawl (which was used for the drums)
Modified the handle today. I had no need to weld mine but I did mine a slightly different way to gain some adjustment and make up for the slack in the cable since my stock equalizer cable is non-adjustable. Not sure if it's possible to buy and adjuable equalizer by itself? Like that guy used. Just need to tweak a thing of two and I might have a working e-brake by tomorrow. Good info guys. Sorry for the thread hyjack....
