rsw007 said:4.10 gears,pullies,70mm t/b,76mm mass air,elec. fan,k&n panel filter,adj. fuel reg. set @28psi and timing @14 degrees,bbk shorty headers,h-pipe,super turbo muffs with dumps,sub frame con.,driveshaft loop,rebuilt tranny with valvebody and clutches and mech diode drum,9.5" edge converter with 3000 stall,steeda hardcore upper and lower control arms,lowering springs in rear and drag springs in front with cheap monroe shocks and struts. amer. racer g60 tires dot legal,weld draglights
weight removed-front and rear sway bars,dog bone on rearend,tail pipes,smog pump,spare jack and sound mat. in this form it ran 13.35@99mph in perfect weather. then went back after removing p/s and went 13.34@99mph in poor weather.
ive since removed the a/c, fog light mounts and bar and moved battery to the rear and put a fiber glasshood on.now i hope to run a 13.299 in good weather.
Your times are totally believable...willys1...I bet if you did every bit of that and your car weighed the same as his you would get those times...
FastGT94 - I did not see a weight on the clutch fork...I looked quickly when I did but didn't see one (I'll double check tonight after work)...Yeah the clutch cable was to loose causing the quadrant to vibrate which made the pedal vibrate...
