ok for the set up i m getting
i found a 73mm mass airflow sensor for 30lb injectors. for 195 from cj pony parts
set up is
dss 306 short block long rod. 9to1 compression
afr185cc heads
tfs stage 2 cam
holley systemmax intake
75mm throttle body
30# injectors
msd ignition system
if 73mm isnt good what should i try to find
thanks
dan
set up is
afr185cc heads
tfs stage 2 cam
75mm throttle body
30# injectors
msd ignition system
thanks
dan
