Just had my car dynoed, are these #'s good for my mods?
aj1025
136
Tyler Texas
I just got home an hour ago from Lewisville texas. The place i had my car dynoed is called speed works, bunch of good guys there, it was a long drive but worth the $45.00 for three pulls. Anyway i have no way of posting my dyno sheets, but with the mods that are in my signature are these #'s good for what's on my car. I know that the auto trans is killing my rear power but here are the #'S. First run timing set @14 degrees 243.8 HP and torque 248.1 then the second run timing set @14 degrees and 234.7 HP and 275.1 torque an the third run set timing adjuster to 16 degrees and 242.2 and torque was 282.3. Are these #'s where they should be for an auto? They told me that these were good #'s and that the air/fuel ratio was good 12-13.
1990StangLX said:
you have to be the biggest idiot ever to post here. how can you troll and spell every word wrong? you further reinforce the stereotype that camaro owners are honestly stupid.
amen to that.
the hair from his mullet must be getting in his eyes, so he can't see to spell correctly :notnice:
btw-those look like good numbers to me for an auto :nice:
I can't go with long tube headers because the entire state of texas is eventually going to go to emissions testing when having your car inspected, so i don't want to spend two days removing the exhaust and installing the factory exhaust (cats) to pass inspection then re-install the longtubes, too much of a pain.
Is Texas doing away with L/T's, or just enforcing emissions? Here in NC most of our counties are going with emissions testing, but in most places, L/T's are fine as long as you have cats on your midpipe.
Just a thought, then all you would have to do is bolt on a catted mid pipe instead of swapping headers and all :nice:
Sorry if i was misunderstood, no texas isn't doing away with longtubes, just i would like to have all the power that the longtubes can give me without cats. Puting cats behind the longtubes defeats the purpose, the cats will be killing like 10 hp, so really, you want see but a 10hp gain if lucky, i'm guessing. What i meant was if i put on longtube headers without cats it will be a pain to remove all that exhaust and put the factory h-pipe on to have it inspected. I now can remove just my offroad h-pipe and re-install my factory h-pipe in about two (2) hours, this is alot easier.
I don't want to get flamed or anything... but aren't those numbers a little low. Granted it is an automatic, but with all his mods I expected higher numbers. I thought the baseline for a stock 99+ GT was around 230 to the wheels? If you ad up the horsepower that other people have dynoed with similar performance mods...
Mac Offroad H Pipe Exhaust +10
Steeda Underdrive Pullies +5?
Steeda Timing Adjuster
K&N Air Filter With Silencer Removed +3?
BBK 75MM TB and
C&L Upper Intake Plenum +15
total of +/-263 hp at the wheels
I'm actually in the process of buying the c/l plenum too and the pullies etc... and I will be dynoing my car also. I calculated bigger numbers, but I guess I'll just have to wait and see. :shrug:
Autos dyno about 219 to the rear wheels. I think they're great numbers. :)
