- May 1, 2005
- 65
- 1
- 0
I just installed my JLT CAI and WOW! I didn't think I would notice any difference seat of the pants wise, but I did. It really looks great and brought on some sotp power. The RPM's climb much faster and my stang seems to be idling much smoother. I've always heard that the stock air box with a K&N panel filter was a pretty good set-up, and it probably was. However, it doesn't compare to what I've got now. There are some fitament issues that I have to work out, but it seems to be staying on there. I'll have to keep my eye on the connection to the throttle body since it doesn't appear to be real solid. Right now I've got my stock throttle body and it requires an adapter since the opening is so small. So they supply you with a thick rubber adapter that slides over the TB to increase its diameter. The upper elbow then pulls over the TB with the adapter on it. It's rubber on rubber so its pulling. When I install my Edelbrock RPM II intake and 70mm TB I should be good.
