| 3M Product | Type / Base | Liner Color | Common Thickness | Typical Use / OEM Applications | Temp Resistance | Notes |
| 4229P | Acrylic Foam Tape (Automotive) | Red polyethylene film | 0.76 mm (0.030") | Exterior automotive trim, body side moldings, door edge guards, spoilers | Up to 200 °F (93 °C) continuous | The gold standard for OEM trim; used by GM, Ford, Toyota, etc. Slight gray foam appearance. |
| 06384 / 06386 / 06397 | Automotive Acrylic Plus | Red liner | 0.8 – 1.1 mm | Heavy exterior badges, fender flares, rocker moldings | Up to 250 °F (121 °C) short term | 06384 is the direct replacement for 4229P in many kits; better adhesion to modern clear-coat paints. |
| 5952 | VHB General-Purpose (Black Foam) | Red liner | 1.1 mm (0.045") | Universal bonding—metal to plastic, spoilers, emblems | 250 °F short term | Ultra-strong, somewhat flexible; favorite for spoilers or high-load trim. |
| 4941 / 4950 Series | VHB Industrial Gray Foam | Red liner | 1.1 mm | Emblem, badge, and sheet-metal bonding | 300 °F short term | Bonds dissimilar materials, including aluminum and composites. |
| 4910 / 4910F | Clear VHB (Acrylic) | Red liner | 1.0 mm | Invisible attachment for glass or clear lenses | 300 °F | Great for interior clear lenses, light covers. Looks slick behind acrylic panels. |
| 5955 / 5962 | VHB Thick Black Foam | Red liner | 1.6–2.3 mm | Heavy panels, spoilers, exterior door moldings | 250 °F | Extra-thick for irregular surfaces or slight gaps. |
| 3610 / 3615 Automotive Performance | High-Temp Acrylic Foam | Red liner | 0.8–1.6 mm | Exterior moldings in hot climates (AZ, TX) | 300 °F | Designed for high radiant heat zones; some OEM roof rail installs. |
| PT1100 / PT1500 | Acrylic Plus, Next-Gen OEM | Red liner with black logo print | 0.8–1.5 mm | 2020-on OEM body trim, radar sensors | 300 °F | High peel strength; compatible with paint systems including ceramic clear coats. |
