Leaf Spring Suggestions
  • Thread starter Thread starter kylehamilton79
  • Start date Start date Apr 7, 2009
kylehamilton79
66
Lubbock, TX
Apr 7, 2009
  • Apr 7, 2009
I need to replace the rear leaf springs on my '67 so I can put my wheels and tires back on without it bottoming out and rubbing the tires. I have seen some 4 1/2 leaf mid-eyes that I think will work. My question is, I already installed some 620 lb. drop springs on the front, so the car sits level now. I am worried about putting rear springs on and it sitting lower in the rear.
Also, any suggestions on which company to get them from or which brand would help too. They all seem pretty much the same from all the different mustang suppliers, except for the Grab-A-Trak from Mustangs Unlimited. Thanks for the help.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Apr 8, 2009
  • Apr 8, 2009
If you are worried about the back being too low, use standard eye 4 1/2 leafs. If you have original leafs, any new spring will probably raise it considerably.
Mil1ion
48
  • Apr 8, 2009
When I replaced the leaf springs I just had the spring company re-draw them to a higher spec....to which they sat too high.... so I took them back and had them draw them to a slightly lower spec...and now after 20 years they still sit perfect.
I had the luxury of having a spring company maker in the same city I live in ,with friend that worked at the service counter.
G
GNGREN
144
Carroll Valley, PA
Apr 8, 2009
  • Apr 8, 2009
I put a set of 5 leaf mid eys from Laurel Mountain Mustangs on my 67 this past winter. I have only put about 1.5 miles on her. Had to drive her to my Fathers shop, as I ran out of room in mine. She rides pretty stiff but it is livable. She actually sits about the same as the original 40+ year old saggy springs did. Which looks pretty good. I just got tired of her bottoming out all the time with the old springs on it. I don't have any pictures of her as she has been on jack stands for a while now, doing a T5 install at the moment.
CochinoFilipino
171
CA
Apr 8, 2009
  • Apr 8, 2009
I suggest installing proper bumpstops. Regardless of which springs you choose to run,
the axle should hit the bumpstops before the tires rub
Z06killinSBF
457
McKinney, TX
Apr 11, 2009
  • Apr 11, 2009
I run the 4-1/2 leaf rev eyes and my tire is about 1/2"-1" from the wheel well.
kylehamilton79
66
Lubbock, TX
Apr 14, 2009
  • Apr 14, 2009
Thanks for the help. Still not sure which ones I am going to buy. I will probably go with the 4 1/2 standard eye for now and see how it sits.
BornInAFord
199
Bend, OR 97701
Apr 16, 2009
  • Apr 16, 2009
If you want to upgrade to a stiffer leaf but with better ride and faster reflexes, you might consider fiberglass mono-leafs from Flex-a-form (get them from Moneymakerracing.com). More expensive ($400 vs $200) , but it will save a lot on weight (8lbs each instead of the stock 4 leaf's 38lbs each or the 5 leaf's 45 lb each heft). Since I put mine on I have had no regrets and am always amazed at the lateral stiffness and superior rebound from my old steel leaf springs. Just a thought.
Daniel
BornInAFord
199
Bend, OR 97701
Apr 16, 2009
  • Apr 16, 2009
Oh, and the eyes are reverseable with the FAF springs (although you have to be careful when removing and reinstalling the eyes so as not to damage the ends and so as to get a good bond again). I dropped 1/2" when I reversed the spring eyes.
Daniel
kylehamilton79
66
Lubbock, TX
Apr 16, 2009
#10
  • Apr 16, 2009
  • #10
I will look into the FAS springs. I like that they are lightweight, since I will be installing them by myself, and like that I can reverse the eyes if it sits too high or too low. I still have a couple of weeks until I make my purchase. Thanks.
BornInAFord
199
Bend, OR 97701
Apr 16, 2009
#11
  • Apr 16, 2009
  • #11
Here are some pics of the FAF springs. Sorry for the dirt, but the car is street driven.
Front spring eye. Spring eyes are bolted in. I had an engine oil leak and it spraycoated everything under the car
kylehamilton79
66
Lubbock, TX
Apr 16, 2009
#12
  • Apr 16, 2009
  • #12
Do your springs use the shackles in the rear like traditional leaf springs do? I can't tell from the pictures.
T
truck90278
382
Redondo Beach, CA
Apr 16, 2009
#13
  • Apr 16, 2009
  • #13
we also have the flex form springs, although we havn't had much time on the street, we are happy with them. they use the stock shackles . ours are 225 # springs.
BornInAFord
199
Bend, OR 97701
Apr 16, 2009
#14
  • Apr 16, 2009
  • #14
I have heavy duty aftermarket shackles but the stock ones will work. FAF supplies the bushings both front and back, so the stock lower shackle bushings aren't needed.
I have the 200lb-in springs. They compare in road stiffness to probably a 165# 4 1/2 leaf or so, but they react much more quickly. They were a great upgrade.
Daniel
kylehamilton79
66
Lubbock, TX
Apr 16, 2009
#15
  • Apr 16, 2009
  • #15
I think those will work. I will call the guys at moneymaker next week and get a set ordered. Thanks Daniel.
J
Foxbody mustang throttle body return spring
  • Jakub2537
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 18, 2026
86HO5.0
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
M
Gifted a Junk 1976 Mustang II with plans for a radical conversion!
  • MXGerry
  • Apr 29, 2025
2K
1974 - 1978 Mustang II Talk & Tech Mar 12, 2026
MXGerry
M
