Gentlemen,
I got some fan shroud hardware from LMR that was missing from my kit that this install uses to secure the fans to the radiator. It has been about 4 hours since I received the package, and I am no closer to getting the fans secured, mostly because of the lower clips. I can't seem to get them to clip onto the radiator. I've tried pushing down on them with a breaker bar, I've tried pulling them down with the edge of a wrench, I've tried prying them open with a flathead screwdriver, I've moved the radiator around to try to get a better angle, and nothing seems to have worked. They either spring off, or don't reach high enough to secure the bottom of the fans. I'm thinking about using zipties and just accepting that the fans will be a little loose on the bottom, but if anybody else has a better idea, please let me know.
I have completed a simple wiring diagram to demonstrate how I plan to connect this thing once I have everything installed, I'll update it with wire colors later when I can check:
