Lifter Preload?
  • Thread starter Thread starter mikemustang289
  • Start date Start date May 17, 2006
M
mikemustang289
224
mesa, az
May 17, 2006
  • May 17, 2006
I set my lifter preload a 1/4 turn on the polylocks. Now while driving and this is only at around 2000-2500 rpm, it sounds as it there is some valvetrain noise. Loud enough where I can hear it from inside the car. This could be an exhaust leak, I could be wrong, but will more preload, say 1/2 turn cure valvetrain noise?
The noise will occur under load while driving or if I just raise the rpm in nuetral.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 17, 2006
  • May 17, 2006
comp cams instructions say that you need to set at 1/2 inch turn not 1/4. That being said i followed the instructions exactly and i still have some rocker noise i am going to do it again with another 1/4 turn.
G
grn92conv
28
  • May 17, 2006
I like to use a half of turn past 0-lash.
aleborjas
610
  • May 17, 2006
i like to use 1/4 turn because i feel the engine little faster and i dont care about little valve train noise
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 17, 2006
  • May 17, 2006
looks like you read the instructions. The other timg is you have to adjust the lash at different points for the intake and exhaust valves. here is the link to instructions.
http://www.compcams.com/Technical/Instructions/Files/250.pdf
352Ford2
393
Seattle,WA
May 17, 2006
  • May 17, 2006
you guys know what a lash loop is?
try one out, you might pick up some power (although it is more of a solid cam thing)
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 17, 2006
  • May 17, 2006
could you explain lash loop?
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
Resolved Noisy Valvetrain
  • PonyGTrider
  • Jun 15, 2024
5K
Fox 5.0 Mustang Tech Jun 19, 2024
PonyGTrider
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
