Losing Weight Permanantly
Jack & spare
No Airbags
Rear seat belts
Smog equipment
Sound deadening
Front sway bar
Gut the trunk
Strut Tower Brace
Carpet insulation
Dog bone
ABS sensors in the front
Aluminum pulleys
Front seats replaced w/ Corbeau Forzas (16 lbs ea.)
Fiberglass hood
Tubular K member
Tubular A arms
Eibach Drag Launch Springs
Aluminum heads
Cut out of the inside of the door that doesn't efect the windows, motor, and door panel
You probably add another pound with 4 hood pins and hardware, but you save weight by
removing the hood latch, hood prop rod, and hood hinges
Losing Weight For Racing Day
Rear seats
Wipers
Floormats
Rear interior panels (next to the seats)
Remove woofers, amplifier, stereo
Front passenger leather seat
Rear Spoiler
Each gallon of gas is 6 pounds so I only run 1/4 tank.
Free & Cheap Mods
Ignition Timing (advance timing, usually 14*)
Remove air silencer
Adjustable Fuel Pressure Regulator(richen the fuel)
Short belt(bypass a/c, power steering, smog pump)
Underdrive pulleys
Synthetic fluids for general tune up(not cheap but worth it)
Jack & spare
No Airbags
Rear seat belts
Smog equipment
Sound deadening
Front sway bar
Gut the trunk
Strut Tower Brace
Carpet insulation
Dog bone
Aluminum pulleys
Fiberglass hood
Tubular K member
Tubular A arms
Aluminum heads
Rear seats
Wipers
Floormats
Rear Spoiler
Free & Cheap Mods
Remove air silencer
Underdrive pulleys
