Coyote Valve Cover Leak Fix | GT500 "Predator" Aluminum Cam Covers - How To Install
View: https://www.youtube.com/watch?v=ZHgtlgfdtqk
If you have an oil leak from your gen 1 or gen 2 Coyote engine valve covers, this video is for you. Landan explains the TSB, removes the OEM valve covers, and installs a new set of GT500 valve covers.
*TSB 19-2309 Info*
Some 2015-2017 Mustang vehicles equipped with a 5.0L engine may exhibit an oil leak from either valve cover gasket. This may be due to the valve covers warping due to excessive heat. To correct the condition, follow the Service Procedure steps to add fasteners to both valve covers.
*Product Links*
Aluminum Cam Covers:
https://lmr.parts/M6067M52S
Coil Covers:
https://lmr.com/item/M6P067M50BL/mustang-gt350-coil-covers-black-ford-performance
GT500 Valve Cover Item # M6067M52S
GT500 Valve Cover MPN # M-6067-M52S
*Vehicle Fitment*
Chassis: S550 Mustang
Trim: GT, GT500
Year Ranges:
- GT: 2011, 2012, 2013, 2014, 2015, 2016, 2017
- GT500: 2020, 2021, 2022
*Tool List*
Microfiber or Shop Towels
All-purpose Cleaner
Brake Clean
O-ring/Seal Lube
Fresh Razor Blades
Brush
Vacuum
Pick Set
3/8" Socket Set
1/4" Socket Set
1/4" Extension Assortment
1/4" Swivel
Ratcheting Wrench Set
*Torque Specs*
Valve Cover Bolts - 89 in-lb
Coil Pack Bolts - Hand Tight
*Chapters*
00:00 - Video intro & TSB info.
01:53 - GT500 valve cover overview.
02:54 - Removing engine parts.
05:45 - Removing the valve covers.
13:30 - Cleaning the cylinder heads.
15:17 - Prep the new valve covers.
18:04 - Install the new valve covers.
24:37 - Final thoughts & outro.
*Social*
YouTube:
https://www.youtube.com/user/latemodelrestoration
Facebook:
http://www.facebook.com/latemodelresto
Instagram:
http://instagram.com/latemodelresto
TikTok:
https://www.tiktok.com/@latemodelresto
#lmr #fordmustang #
Use of this video is subject to the terms as set forth in our LMR Install Video Disclaimer |
https://lmr.com/page/lmr-install-video-disclaimer
