LMR Youtube Channel
Stroker 302?! Mystery Modded 1995 Mustang GTS Hits the Dyno!
View: https://www.youtube.com/watch?v=3qJcrXEdfAE
This 1995 Mustang GTS has been around the LMR block a time or two. This go-round it has a host of aftermarket goodies one of which is unknown to us; the displacement of the engine.
*Product Links*
Shop SN95 Mustang Parts: https://lmr.com/1994-04-Mustang
*Watch*
Dyno Playlist:
View: https://www.youtube.com/playlist?list=PLMti2eKQ3th_SMVaWhDt8PIAuuwAZBL0I
*Dyno Information*
- Unknown Engine Displacement
- Trickflow 11R 190cc Cylinder Heads
- Trickflow Stage 2 Camshaft
- Anderson Power Pipe
- 75mm Throttle Body
- Cobra Upper/Lower Intake
- Power Steering Delete
- Long Tube Headers w/ Free-flowing X-Pipe
- Flowmaster Cat Back
- T5 Transmission (4th gear pull which is 1:1)
- Aluminum Driveshaft
- Believe to be 3.73 Rear Gear
- 17" Cobra R Style Wheels w/ 275/40/17 Tires
- 93 Octane Fuel
- Holley Terminator X ECU
*Chapters*
00:00 - Car backstory & modifications.
01:46 - Dyno run.
02:40 - Dyno results.
03:30 - Final thoughts & outro.
*Social*
YouTube: https://www.youtube.com/user/latemodelrestoration
Facebook: http://www.facebook.com/latemodelresto
Instagram: http://instagram.com/latemodelresto
TikTok: https://www.tiktok.com/@latemodelresto
#lmr #sn95mustang #dyno
Use of this video is subject to the terms as set forth in our LMR Install Video Disclaimer | https://lmr.com/page/lmr-install-video-disclaimer
2013-2014 S197 Mustang HID Projector Headlights (Factory-style Replacements) - How To Install
View: https://www.youtube.com/watch?v=tNCt-YIEhzY
In this video, Jude explains the process of installing new factory-style headlights in an HID-equipped 2013-2014 S197 Mustang.
*Product Links*
13-14 Factory-style Headlights: https://lmr.com/item/LRS-13007COE-K/mustang-headlight-kit-hid-13-14
*Watch*
How To Adjust 2010-2014 Headlights:
View: https://youtu.be/49UgpeQy5vE
How To Remove Front Bumper:
View: https://youtu.be/OACbzFYIEfY
*Vehicle Fitment*
Chassis: S197 Mustang
Year Range: 2013, 2014
*Tool List*
Microfiber Towels
All Purpose Cleaner
1/4" Socket Set
1/4" Extensions
T10 Torx Driver
*Torque Specs*
Headlight Retaining Bolts - Hand Tight
Ballast Screws - Hand Tight
*Chapters*
00:00 - Video intro & explanation.
00:58 - Disconnect negative battery cable & remove front bumper.
01:09 - Remove the headlights.
01:42 - Remove the ballast & bulb.
02:58 - Transfer the ballast & bulb.
05:21 - Reinstall the new headlights.
06:25 - Reinstall the front bumper & align the headlights.
06:36 - Final thoughts & outro.
*Social*
#lmr #s197mustang #latemodelresto
Coyote Swap New Edge Exhaust Clips: SVE Shorty Headers w/ Borla XR-1 Mufflers & Catted X-pipe
View: https://www.youtube.com/watch?v=uCcyZzT8kZ0
The exhaust note on any car can make or break it. We always liked the sound of the Borla XR-1 muffler on Project Keeping Comp, so it stayed in place whenever the Coyote swap was complete. Arguably, a mid-muffler setup really helps the "high pitchness" of a Coyote engine.
*Product Links*
SVE Coyote Swap Shorty Headers: https://lmr.parts/SVE-9604CS-K
Borla XR-1 Muffler: https://lmr.com/item/BOR-40941/borla-xr-1-sportsman-muffler-2-5-40941
Bassani Catted X-pipe: https://lmr.com/item/BE-46993/Mustang-X-Pipe-Catalytic-5-Speed
*Watch*
Coyote Swap New Edge How To Guide:
View: https://youtu.be/mIC6f5kXPHc
Coyote Swap New Edge Dyno:
View: https://youtu.be/0XbeNd4V0FY
Project Keeping Comp Full Resto:
View: https://youtu.be/OC5LdW73LbM
*Vehicle Fitment*
Chassis: New Edge Mustang
Year Range: 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004
*Chapters*
00:55 - Idle clips & standing revs.
01:47 - Takeoffs & fly-bys.
02:22 - ASMR driving.
*Social*
#lmr #newedgemustang #coyoteswap
LMR 2025 Cruise-In Announcement
View: https://www.youtube.com/watch?v=DGO1IaDyeFU
We greatly appreciate your patience. Once we have more details to share, we will make sure to update everyone as soon as possible!
Because of everyone's overwhelming support over the years, we have decided to take 2025 off for the LMR Cruise In to allow proper planning for the next one. But trust us when we say this: The next LMR Cruise In will be bigger and better than ever before. So, thank you to everyone who attends our event every year. It truly does mean a lot to us!
Thank you again to all our customers, followers, and supporters. And as always, keep it here with the real Ford enthusiasts, LMR.com.
#lmr #LMRcruisein
Landan's 2000 Ford SVT Lightning Dyno | "Forum Kool-Aid" Mods & CRAZY Loud Supercharger Whine
View: https://www.youtube.com/watch?v=y5F207usyro
Landan has owned his Lightning nearly 15 years at the time of this video. It's a great example of a silver Lightning with basic bolt-ons.
*Product Links*
Shop 1999-2004 Ford Lightning Parts: https://lmr.com/Ford-Lightning
*Watch*
Dyno Playlist:
SVE Ford Lightning Steering Wheel:
View: https://youtu.be/oYlI2DAUP64
*Dyno Information*
- Stock 5.4L Engine w/ ~65k Miles
- Ported Eaton Supercharger
- 6lb Lower Pulley (~16 psi of boost)
- "Open Filter" Intake
- C&L Inlet Elbow
- Factory Exhaust Manifolds
- Free-flowing Mid-pipe
- Bassani Cat Back
- Electric Fan Conversion
- Fluidyne Heat Exchanger
- 4R100 Transmission (3rd gear is 1:1, but truck was pulled in 2nd to prevent downshift)
- Factory Aluminum Driveshaft
- 3.55 Rear Gear
- 20x10" SVE 99-00 Style Rear Wheels w/ 295/40/20 Nitto NT555G2 Tires
- 93 Octane Fuel
- Custom Tune
*Chapters*
00:00 - Truck backstory & modifications.
02:45 - Dyno run.
03:06 - Results & SCT chip explanation.
05:11 - Final thoughts & outro.
*Social*
#lmr #fordlightning #supercharged
One Key Does It All!! // 1979-1993 Fox Body Mustang: 5.0 Resto Single Key Lock Conversion Kits
View: https://www.youtube.com/watch?v=FlnqMgyEeWo
Say goodbye to having multiple keys for the door, ignition, and trunk locks on your 1979-1993 Mustang with these 5.0 Resto single-key conversion kits. There is nothing more annoying when trying to unlock your Fox Body than having to try multiple keys to fumble with. Ford knew of this issue, even having it as a factory option on SSP Police Mustangs. Well, now you can simplify your Fox Body with 5.0 Resto's single key conversion to have the same convenience. Quick and easy installation in under an hour makes for a simple way to keep your vehicle secure! The hardest part of the entire installation is removing your door panels and disconnecting the battery.
These conversion sets include an ignition cylinder, two door lock cylinders, a trunk lock cylinder, two matching square-style keys, and all the needed seals and retainers! 5.0 Resto includes a glove box lock cylinder for the 1987-1993 Mustang to round out the last lock. This is a great solution to replacing your locks without having to get a locksmith to make new keys for your Mustang. These cylinders feature stainless steel construction with machined bezels to give you a great OE look on the exterior.
*Product Links*
Machined Bezel: https://lmr.parts/LRS-21984D-SK
Black Bezel: https://lmr.parts/LRS-21984A-SK
*Watch*
How To Install Ignition Cylinder:
View: https://youtu.be/y-lEf6gOPHg
How To Install Door Lock Cylinders:
View: https://youtu.be/1Epvzf4AXRw
Ignition Cylinder Removal (Alternate Method):
View: https://youtu.be/C_I-eeV2uXo
*Vehicle Fitment*
Chassis: Fox Body Mustang
Year Range: 1979, 1980, 1981, 1982, 1983, 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993
*Chapters*
00:00 - Backstory of the Fox Body single key.
00:56 - Single key conversion kit overview.
02:00 - Fitment notes & other videos of interest.
02:27 - Final thoughts & outro.
*Social*
#lmr #foxbody #carrestoration
