BluePrint Engines 302ci Crate Engine: Chassis Dyno Runs in a Fox Body Mustang | Can it make 300rwhp?
View: https://www.youtube.com/watch?v=AmIxumRd0ck
Crate engines and power numbers go together like peanut butter and jelly. However, it's rare to see what a crate engine will make at the rear wheels due to the myriad of setups that exist in the hot rodding world. Whenever we started to offer BluePrints 302ci engine, we wanted to get one in a Fox Body Mustang and put it on our chassis dyno. Well, the opportunity came a knockin' since our 1988 GT, dubbed Project Introvert, needed an engine.
*Product Links*
BluePrint Engine:
https://lmr.parts/BPE-302RCT
Engine Finishing Kit:
https://lmr.parts/LRS-ENGINEKIT
Holley Terminator X Kit:
https://lmr.parts/HLY-550937F
*Watch*
BluePrint Engine Overview:
View: https://youtu.be/chC1Wc-66pw
BluePrint Engine Sound Clips:
View: https://youtu.be/SHFarhg6MyU
5.0 Resto Center Console:
View: https://youtu.be/MVUijkDLmgI
Holley Terminator X ECU Kit Overview:
View: https://youtu.be/-2RG9RsMJ-8
*Relative Dyno Information w/ Baseline Setup*
- Temperature: 92 degrees
- Humidity: 49%
- Stock 5.0L Engine
- Clutch Fan
- Free-flowing H-pipe
- Smog Pump Delete Pulley (Dyno use only.)
- Flowmaster American Thunder Cat Back
- T5 Transmission (4th gear pull which is 1:1)
- Factory Driveshaft
- 2.73 Rear Gear
- Rear Wheels: 17" SVE Mesh Wheel w/ 275/40/17 Nitto Tires
- Rear Brakes: SN95 Cobra Rotors (11.65")
- 93 Octane
- Holley Terminator X w/ Basic "Startup" Tune
*Relative Dyno Information w/ BluePrint Engine*
- Temperature: 87 degrees
- Humidity: 31%
- BluePrint Engines 302ci Crate Engine (391hp flywheel rating)
- Holley Systemax Upper/lower Intake
- Factory-style Cold Air Intake
- Contour Electric Fans
- Shorty Headers
- 2.73 Rear Gear
- 93 Octane Fuel
- Holley Terminator X w/ Custom Tune
*Chapters*
00:00 - Video intro & explanation.
03:25 - Backstory on Project Introvert.
05:41 - Engine specifications & dyno technical data.
07:16 - Baseline dyno run & results.
08:03 - BluePrint engine dyno run, results, & comparison.
10:20 - Final thoughts & outro.
*Social*
YouTube:
https://www.youtube.com/user/latemodelrestoration
Facebook:
http://www.facebook.com/latemodelresto
Instagram:
http://instagram.com/latemodelresto
TikTok:
https://www.tiktok.com/@latemodelresto
#lmr #foxbody #engine
Use of this video is subject to the terms as set forth in our LMR Install Video Disclaimer |
https://lmr.com/page/lmr-install-video-disclaimer
