LMR Youtube Channel
Modernize your Fox Body Mustang! FoxLox Keyless Entry System - Overview & Install
View: https://www.youtube.com/watch?v=lqWmOsJAEOo
Seamlessly add a keyless entry to your 1985-1993 Fox Body Mustang coupe or hatchback with FoxLox USA's plug-and-play keyless entry system. Available as a "base" kit without actuators, or a kit that includes new door lock actuators. We recommend the full kit just for the peace of mind knowing you'll have new actuators. If you opt for the "base" kit, make sure the existing actuators are in good working condition.
*Product Links*
Base FoxLox Kit: https://lmr.parts/LRS-FOXLOX
FoxLox Kit w/ Actuators: https://lmr.parts/LRS-FOXLOX-KIT
Wiring Diagrams: https://lmr.parts/automotive-guides-books-literature
*Watch*
81-86 Door Panel Removal:
View: https://youtu.be/V0oWfHkX_8g
87-93 Door Panel Removal:
View: https://youtu.be/AOK47vzs3bs
How To Replace Door Lock Actuator:
View: https://youtu.be/6B3CAYfYXDg
*Social*
YouTube: https://www.youtube.com/user/latemodelrestoration
Facebook: http://www.facebook.com/latemodelresto
Instagram: http://instagram.com/latemodelresto
TikTok: https://www.tiktok.com/@latemodelresto
#lmr #foxbody #foxlox
Use of this video is subject to the terms as set forth in our LMR Install Video Disclaimer | https://lmr.com/page/lmr-install-video-disclaimer
PSA 5.0 Resto Door Lock Actuator
View: https://www.youtube.com/watch?v=nUk-_pM4YC4
Over years of use, the door lock actuator can become rusted, or the solenoid can stop functioning. Replace that non-functioning door lock actuator with an improved, stronger, and smoother operation design door lock actuator. These door lock actuators include a durable rubber boot designed to keep foreign contaminants out of the solenoid.
New and non-manufactured actuators will put your mind at ease, knowing that you will have many more years of service! 5.0 Resto includes a new rivet are made to replicate the OE rivets as closely as possible with the correct diameter head and durable satin black finish. This 1/4" rivet has the proper length and engagement to keep the actuator anchored in place for years to come.
Check out all of the other kits that we offer with the door lock actuator!
1979-93 5.0 Resto Door Lock Actuator: https://lmr.com/item/LRS-21842R/1979-93-Mustang-Door-Lock-Actuator
1979-93 Mustang Door Lock Actuator Kit: https://lmr.com/item/LRS-21842K/79-93-Ford-Mustang-Door-Lock-Actuator-Kit
1979-93 Mustang Door Lock Actuator & Power Window Motor Master Kit: https://lmr.com/item/LRS-23394AK/79-93-Mustang-Door-Lock-Actuator-And-Power-Window-Motor-Master-Kit
Yet Another Stock 2024 Dark Horse Mustang Dyno Run | Handling Pack & Tremec TR 3160 6-speed Manual
View: https://www.youtube.com/watch?v=K5BxUQklV2Y
It took a while to receive our 2024 Dark Horse Mustang due to the handling pack cars taking forever to build. Well, we finally got ours and put a few hundred miles on it before getting some baseline dyno numbers. You won't find any extra sorcery in this video with carbon traps and fuel changes. Just some good old fashion baseline numbers.
*Product Links*
2024-2025 S650 Mustang Parts: https://lmr.com/2024-Mustang
*Watch*
2024 Mustang GT Stock Dyno:
View: https://youtu.be/5pFxbnPFHKE
*Relative Dyno Information*
Ambient Temperature: 79°
Relative Humidity: 55%
Gen 4 5.0L Coyote Engine w/ ~442 Miles
3.73 Rear Gear w/ Torsen Differential
19" OEM Dark Horse Handling Pack Wheel w/ 315/30/19 Pirelli Trofeo Tires
93 Octane Fuel
*Chapters*
00:00 - Video intro & explanation.
00:50 - Dyno run.
01:30 - Dyno results.
02:12 - Final thoughts & outro.
*Social*
#lmr #mustang #dyno
2024 S650 Dark Horse Mustang w/ 600a Package, Handling Pack, & Recaros | How much does it weigh?
View: https://www.youtube.com/watch?v=JFH4wtyvA5A
The gross weight of a vehicle is a popular piece of information that us as enthusiasts like to know. In this video, Jud weighs a 2024 Dark Horse Mustang with the 600A package, handling pack, & Recaro seats. Additional vehicle information can be found below. Also, it's important to consider the variances in scales. The weight of each car can slightly differ from scale to scale.
*Car Information*
Fastback
600A Package
Handling Pack
Recaro Seats
Fastback
Tremec TR-3160 6-speed Manual Transmission
1/2 Tank of fuel
A gallon of gasoline weighs 6.1lbs
*Product Links*
*Watch*
2024 Dark Horse Mustang Stock Dyno:
View: https://youtu.be/K5BxUQklV2Y
2024 Mustang GT Weight:
View: https://youtu.be/HKlN6Cm09ZE
*Social*
#lmr #darkhorsemustang #s650mustang
1990-1993 Fox Body Mustang: 5.0 Resto Lower Dash Trim "Knee Panel" - Overview & How To Install
View: https://www.youtube.com/watch?v=VjeJU0FrzzY
The 5.0 Resto lower dash trim (aka knee panel) for the 1990-1993 Fox Body Mustangs is a factory reproduction of the original. It incorporates the OEM dimensions, tolerances, texture and attaching attributes such as the OE-style clips, textured rubber seal, and anti-rattle pads. The lower dash trim is available in black or paintable (neutral gray) finishes. The black finish is correct for 1990-1993. When painting the gray lower dash trim, be sure and mask or remove the rubber seal and properly prep the trim before painting. Allow 24 hours of cure time before installation. Included with each lower dash trim are factory-style screws.
One small note, the rubber seal may arrive in an irregular position. Carefully use a heat gun to manipulate this back into . This is covered in the video.
*Product Links*
90-93 Black Lower Dash Trim Kit:
90-93 Gray Lower Dash Trim Kit:
Interior Paint: https://lmr.parts/79-93-Mustang-Interior-Paint
87-89 Lower Dash Trim Kit: https://lmr.parts/LRS-6104459B-K
*Watch*
87-93 Center Console:
View: https://youtu.be/MVUijkDLmgI
87-89 Lower Dash Trim:
View: https://youtu.be/bbRf2fvc1DM
*Vehicle Fitment*
Chassis: Fox Body Mustang
Year Range: 1990, 1991, 1992, 1993
*Tool List*
Microfiber Towels
Grey Scuff Pads, Bucket, & Dish Soap
Plastic-safe Prep Spray
SEM Sand Free Adhesion Promoter
Interior Paint
PPE
Masking Tape & Paper
Phillips Head Screwdriver Set
1/4” Socket Set & Ratchet
Heat Gun
*Torque Specs*
Steering Column Screws - Hand Tight
Lower Dash Trim Screws - Hand Tight
*Chapters*
00:00 - Video intro & lower dash trim overview.
02:54 - Paint process explanation & what's in the box.
04:03 - Note about the rubber seal.
04:22 - Remove the existing lower dash trim.
05:12 - Install the lower dash trim.
05:50 - Final thoughts & outro.
*Social*
#lmr #foxbodymustang #carrestoration
SVE® Forged Series | 19x10/10.5/11" DHP1 Wheels - Review (2005-2025 Mustang)
View: https://www.youtube.com/watch?v=gHvVXAqtubI
Transform the look of your S197, S550, or S650 with a no-nonsense, race-inspired look and function using the matte silver 19x10 SVE DHP1 forged wheel. The SVE DHP1 wheel improves the appearance and feel of your Mustang by combining performance-oriented design with artistic styling. SVE's DHP1 wheel uses forged aluminum, which reduces rotating mass compared to cast or flow-formed wheels. The DHP1 uses inspiration from production race cars to bring a premium wheel that looks and performs exceptionally on and off the track. SVE utilizes a multi-faceted, angular spoke, which provides definition on a simple, split 5-spoke design. Each of these slim wheel spokes arcs down into the recessed center section containing an SVE center cap. Available in three vibrant finishes: matte silver, gloss black, and graphite.
SVE's DHP1 wheel is constructed using a state-of-the-art wheel forging process. SVE forged wheels are manufactured from a single billet piece of 6061 solid aluminum. The billet is heated to extreme temperatures and pressed with 10,000 tons of force, creating its pre-form shape. This compression of the material and thermal cycling allows further grain refinement. The barrel wheel is flow-formed with hydraulic rollers that apply intense pressure to the barrel to increase tensile strength. Precision CNC machining is performed to achieve their final shape and design. Forged wheel manufacturing processes result in a stronger, lighter wheel by eliminating potential cavities, voids, and shrinkage. Due to their refined grain structure, forged wheels are also mechanically more robust, ensuring better resistance to wear and deforming over time. This allows the forged version of the SVE DHP1 wheel to have a thinner spoke without sacrificing structural integrity. The SVE DHP1 Forged wheel is backed by an industry-leading warranty for the ultimate peace of mind!
*Product Links*
SVE Forged DHP1 Wheels: https://lmr.com/products/mustang-sve-dhp1-forged-wheels
*Watch*
DHP1 Flow Formed Review:
View: https://youtu.be/f2Ar9ia4z6I
Wheel Offset & Backspacing Explained:
View: https://youtu.be/euzvLAOYCrM
*Vehicle Fitment*
Chassis: S197, S550, S650 Mustang
Year Range: 2005-2025
*Chapters*
00:50 - Forged process & weight comparison.
02:31 - Wheel design.
03:17 - Wheel finishes.
04:17 - Wheel sizes & specs.
05:10 - Fitment notes & 19x10.5" info.
06:11 - Buying options, warranty, & fitment notes.
06:44 - Final thoughts & outro.
*Social*
#lmr #fordmustang #svewheels
1987-1993 Fox Body Mustang: Defrost Vent Register - Overview & How To Install
View: https://www.youtube.com/watch?v=-x7jb_7ppgs
Designed and manufactured with an OEM fit and finish in mind, this 5.0 Resto defrost vent register is the perfect solution to restore your interior. Each vent register is built to the factory dimensions with durable plastic material using an injection molding process. Factory-style grain and texture are applied to closely match the rest of your interior. 5.0 Resto's Fox Body defrost vent arrives in a black finish but can be prepped and painted to match other interior colors. Each vent has retaining clips and a rubber bumper preinstalled, making it a snap to install into your dashboard. These pre-assembled retaining clips are made from a durable steel construction with a clear zinc coating to prevent corrosion. Lastly, a foam strip is pre-installed on the vent to ensure air is directed to the vent to cut down on vibrations and rattles.
In this video, Landan explains the defrost vent register in greater detail and shows how to remove and install one into a 1987-1993 Fox Body Mustang.
*Product Links*
87-93 Defrost Vent Register: https://lmr.parts/LRS-61044A
*Watch*
*Tool List*
Microfiber Towels
Interior Paint
PPE
Heat Gun
*Chapters*
00:00 - Video intro & defrost vent register overview.
01:22 - Black finish explanation.
02:22 - Fitment notes & paint procedure.
04:12 - Removing & installing the defrost vent register.
*Social*
