Maddening horn problem
  • Thread starter Thread starter CurlyA6
  • Start date Start date Feb 9, 2012
CurlyA6
47
Pacific Grove, CA
Feb 9, 2012
  • Feb 9, 2012
Arrrrrggghhh. I installed a Grant classic wood steering wheel and the cast Mustang horn "button" in my '68 Mustang. The steering wheel installation worked out fine, but the Mustang horn button is simply crazy.
Essentially, the separate instructions that come with the cast horn button say "throw out the spring, and put these three self-adhesive foam pads (about 3/8" square and a little less thick) between the two horn plates, then screw in the three shoulder bolts."
That worked okay, but funky, and the horn is now very sensitive...bumps in the road will set it off. I've tried loosening the bolts to just snug, but that induces a bit of slop between the contact plates and makes the problem worse. I've also tried adding a bit of self adhesive felt (those sticky green circles of felt you can put on the legs of the dining room chair to not scratch the hardwood floor), but no improvement.
Finally, the cast Mustang horn button is supposed to press fit on over the outer contact plate, just friction holding it on. No surprise, no matter how firmly I press the button on over the contact plate, it just dangles and eventually (again, bumps in the road) falls off.
Either this is the most poorly engineered horn button installation in the world, or I'm missing something obvious. Has anyone out there fought this battle before? (Pics available, if that will help).
Thanks.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Feb 10, 2012
  • Feb 10, 2012
The cheap Grant steering wheel has the worst-engineered horn button in the history of autos. I usually use some silicone bathtub caulk to glue it in place so it doesn't fall off at the slightest bump in the road.
soutex
10
  • Feb 13, 2012
Everything you have had happen has happened to me too. I got so mad after the honr button fell in my lap for the 100th time I pulled that wheel off and threw it in the trash. I finally bought a Lecarra MK-4 with a polished disk horn button and it is first rate and I am a happy dude.
G
geordie
576
  • Feb 15, 2012
G
geordie
576
  • Feb 15, 2012
I am having similar issues, previously I used three dabs of RTV to fix the cast horn button to the horn. that worked but a couple of weeks later, the horn came on (faintly) as soon as I turned the ignition key. I was able to stop it by pulling on the cast horn button. The next time I came to start the car, no horn, at all. I'm very interested in trying to resolve this. It's next on my To-Do list, probably won't get to it this weekend though.
M
Gt convertible brake problems.
  • MacMAgoo
  • Oct 2, 2022
3K
1996 - 2004 SN95 Mustang -General/Talk- Oct 15, 2022
CAMTWO1070
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
'88 GT Convertible - Croatia, Europe
  • snovak
  • Oct 9, 2020
  • 23 24 25
49K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
snovak
G
1967 Mustang Brake Light Problem
  • GaryH
  • Sep 15, 2019
4K
1965 - 1973 Classic Mustangs -General/Talk- Oct 22, 2019
GaryH
G
Foxbody Mustang Cruise Control information, location, wiring diagrams
  • Mustang5L5
  • Jan 22, 2021
  • 2 3 4
39K
Fox 5.0 Mustang Tech May 3, 2026
AeroCoupe
