maf conversion
dkins419
187
Michigan
Im gonna convert to maf if i can cheaply otherwise im not going to bother with it til i actually need it. I was wondering what other cars you can take the computer/harness/maf sensor from?
Copied From bbunt302
Just for reference, here's a list of all the compatible years:
89 harness should work for 86-89 as long as you're using mass air.
90 harness will only work in a 90. (B/c of air bags and dual dash connectors)
91 through early 92 harnesses should be compatible (single dash connector, fuel pump relay under driver's seat)
Late 92 through 93 harnesses should be compatible (single dash connector, fuel pump relay under the hood)
Computers from 89-92 are all the same. Look for the A9L sticker on the back cover for a 5 speed that matches your requirements. Example: E9ZF 12A650 AA" with the A9L code.
Check Ebay for the 4 pin Mass Air Conversion wiring harness and connector and save $$$
See MASS air conversion instructions from http://www.stangnet.com/tech/maf/massairconversion.html
