Ok I know I have been driving you all crazy with this MAF stuff but I want to get it right before I do my heads and cam.
Tested the maf sensor today. Red wire is positve with power-Black wire ground and its grounded alright-Green wire is for the sensor and it reads (with the volt tester on 2 volts) .04-White wire reads (with volt tester on 20 volts) .86. I was told and read that the white wire is supposed to be between .5 and .6. While the white wire should be 5 volts. I ve tried two different computers with both the same result. The maf does not seem to make a difference wether its pluged in or not. It runs fine but im afraid that if the maf is not working right that when I put the heads and cam in it wont run at all. That is run like a speed density car cause its an 1988. Am Testing it right? What the heck should I do? Someone please help.
I dont think I ve ever been so frustrated. Thanks guys.
