Magneticas' Build Process
Boone
88
12
28
Central Florida
#23
90sickfox
I didn't really have an issue with the stink...
SN Certified Technician
Mar 2, 2015
4,226
3,490
183
41
#24
Found out some info for 2019 ecoboosts. The recirculation valve is bigger in diameter so Steeda BOV adapter part # 555-3215 will not fit.
Guess I'll contact LMR and let them know. Smh...
This is one of those bad days for me...thought I'd come home and put a smile on my face after work....
...but in a lil'while I wont be able to feel my face. Cheers folks.
90sickfox
Mar 2, 2015
4,226
3,490
183
41
#26
Steeda is trying to tell me that this part...
....will fit inside this part....
They said their Ford contact says the recirculation valve is the same part from 15 to 19. Guess they machined this one bad then.
I could have it machined...but LMR or Steeda need to get this straight before they sell more people bad parts. I have faith in LMR. I'm sure they'll get to the bottom of this.
90sickfox
Mar 2, 2015
4,226
3,490
183
41
#28
LMR is fantastic and offered to refund my money. I opted to have my machinist open it up a little so it will fit. Steeda says they are all machined to 1.200...and it should fit. I'm going with my first statement that the BOV changed in 19 and is now bigger ( proven by my measurements ). The 19 puts out more power and has a few upgrades...I think this includes the BOV. The bolt pattern is the same and the adapter fits in the intake tube but the BOV will not go in the adapter.
If you have a 19 don't buy until you measure your recirculation valve. Would be great if someone else with a 19 ecoboost could measure and post here.
90sickfox
Mar 2, 2015
4,226
3,490
183
41
#29
I wish I had more pics but I was in a zone and forgot to take some.
I opened up the adapter for the recirculation valve. Using a paint pen and painting the inside it was slowly opened up. Found that a mountain dew bottle cap measured almost exactly to the factory recirculation valve. The bottom of the cab by the break off ring was the perfect size. Using that and the paint as a guide I made a perfect fit after about 2 hours. Smh
This was my tool kit...
The recirculation valve is in a tight spot. This 5mm hex swivel made it easy for removal and install. I didn't have to remove anything else or unplug the sensor. ( the factory has tape wrapped around it that would have to be torn to unplug it ). My car is new so....ah...no.
I've got to say this thing sounds amazing. The car finally sounds like a turbo car. No check engine light...and no drivability issues. My car is auto and this thing still sounds great. Ford programmed the valve to open or fluctuate between gears when light on the happy pedal. When more pressure on the pedal boost holds and the valve doesn't open until let off.
Was going to have a friend machine it but it wasn't needed. It's just like porting an aluminum head. Coat with paint or dye. Evenly remove paint....check....coat....grind...check....coat....grind...etc.
I drink too much maintain dew....but luckily I do the dew...
2Blue2
229
98
38
51
Oahu
#30
Now your gonna need a Mt.Dew sponsor/race sticker on her.
Come on it will be worth 15 hp.
90sickfox
Mar 2, 2015
4,226
3,490
183
41
#31
Steeda has been in contact with me just about every day. Those guys really are trying to get to the bottom of this issue. Today they got my vin number and I gave them the measurement that I opened the adapter up to.
Apparently, the parts department is using the same recirculation valve from 15 to 19. Here's a pic of mine in case anyone can chime in with a pic of theirs and the year of the car.
90sickfox
Mar 2, 2015
4,226
3,490
183
41
#32
Steeda has responded again ( great guys over there ). They are going to open up the adapter a bit so it'll fit all model years. The part number on my recirculation valve doesn't exist yet in the Ford parts bin. The depth is the same and the sealing o rings are the same. Just needed a little more machining.
The guys at Steeda have really been great. LMR has also been top notch through this process.
90sickfox
Mar 2, 2015
4,226
3,490
183
41
#33
Um....the line lock on my ecoboost works....
It works really really good....both tires....
Nothing like smoking the factory tires up.
