JBVobra said:
great times, but 4.88 gears??
No, 4.56s. 2400 rpm @ 70 mph.
28 mpg on the highway.
whats the first gear in that T5?
Was 2.95 (similar to your Z06), now 2.92.
how many input/output shafts have you sheared off of the tranny?
None (that was a T45 problem). FYI, I now have G-Force components in my T5, which includes a 26 spline, GM-Style input shaft.
there's a definitive line between having a nice street car that performs well and behaves well as compared to transforming a nice street car into an all out 1/4 mile car with ridiculous gearing and drag suspension.
We all have our opinion of what "ridiculous" is and what a "drag suspension" is, but I'll list my stuff and let you and everybody else decide for themselves.
My 'ridiculous gearing' returns 20-21 mpg going back and forth to work, up to 28 mpg on the highway, can cruise from 25 to 50 mph in 4th (little need to shift), or from 35 to whatever mph in 5th (little need to shift). If I want, I can easily start from a dead stop in 2nd, skip 3rd, and go right to 5th if I feel the need (which is rare).
I don't see the "ridicuous" part here.
My "drag suspension" consists of a set of
X2C Boxer ST control arms with urethane bushings (nothing solid), adjustable shocks and struts (adjust from very loose to very tight), stock rear springs, soft front springs, and an air bag in each rear coil. That's it. What is "drag suspension" about that? I think you'll find those mods to be quite common on many, many F-bodies and Mustangs alike.
Sure, your motor is "stock", but what kind of person wants to cruise around town with 4.88 gears?
1) We've already covered the gearing
2) I covered the "cruise around town" part above
3) It wasn't bad on 4.88s either when I did have them.
Not knocking the times cosby, they're impressive.
Thank you, as are yours.
That nice little 99 cobra has just turned into a 1/4 slave for most peoples taste.
Again, we all have our opinions, but what makes it a "1/4 slave"? It has a very compliant suspension, A/C, nice seats, a nice stereo, stock idle and driving manners, gets good mileage, etc, etc.
You could get very near performance out of a sanely geared F-Bod with a nice cam package. For pretty cheap, too.
No doubt abou that. My only point of disagreement here is your "sanely geared" implication. An LS1 simply doesn't have the rpm potential to take advantage of more gear, or they'd use it. Of course, it doesn't need it either. In the end, the result is very near the same.
FYI...please take no offense to my use of quotes - it simply helps me organize thoughts/responses better.
