man a clutch cable can really make a difference.
  • Thread starter Thread starter Foxfan88
  • Start date Start date Aug 5, 2007
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Aug 5, 2007
  • Aug 5, 2007
yesterday when installing my SC i put on a new clutch cable. its the universal cable from MM, this thing really made a difference. its longer and can be mounted away from the headers alot better. and the clutch feels like a a clutch in a honda or something. i always thought my t5 was just a notchy feeling t5 but after the MM cable i could shift faster, easier and just overall the cable was great!
even came with a little dust boot slipped over the cable on the tranny side.
if you are having clutch problems or cable problems. try the Maximum motorsports cable. made a world of difference.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Aug 5, 2007
  • Aug 5, 2007
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Aug 5, 2007
  • Aug 5, 2007
Thoose covers or boots came stock on mustangs.. they cover the clutch fork to..
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Aug 5, 2007
  • Aug 5, 2007
no this wasnt the metal thing that bolts to the bellhousing its was a small boot on the actual cable. i knew factory had a metal plate that went over the fork and cable. this was an actual rubber boot. i dont have the metal plate.
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Aug 5, 2007
  • Aug 5, 2007
Yeah, Frankie's came with that boot on her MM clutch cable, too. Pretty cool little feature, actually - keeps road grit and crap from getting up in the cable shielding.
DigitalGhost
18
Portland, OR
Aug 5, 2007
  • Aug 5, 2007
I need to install a new clutch cable.
How difficult is it, and what's the best way to go about installing one?
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Aug 5, 2007
  • Aug 5, 2007
my dads clutch cable is REALLY soft...and well the first 5 speed i drove the clutch cable was put damn hard to push in and the clutch didnt engage untill about halfway out(needed adjusted i bet) and my dads engages about a 1/2" from the floor and is very soft to where its like pushing in the horn...well i pulled out out of the garage ( dad was drunk and needed the stang out to put a few things away... so i got to pull it out and i stalled it :sad:...(i was still use to the ole truck's clutch) i think its time for him to get a new cutch cable... but HEY he let me move his car....thats a s step..maybe by next year ill get him to let me drive it on the street
that being said...where can we get a new clutch cable from it.
Mustang78
486
Aberdeen, WA
Aug 6, 2007
  • Aug 6, 2007
when i did the 351w i looked over the clutch cable and it was broken except for 1 strand...another day or so it would have broken, guess i got lucky. I just bought a parts store brand and it works awesome, MUCH smoother clutch action that stock, the CF dual friction clutch is a light pedal
~Mark~
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Aug 6, 2007
  • Aug 6, 2007
I was installing my headers and thought I would pull that shield off my tranny (the one that covers the clutch fork) So I took out the 8mm bolt and could not get that sucker off...is there a trick to theese like a clip or something. I changed a cable on a costomers 94 and it came right off. I want to install a new cable when I do the quad and F/W adjuster but I can't get that cover off my fork...............sorry for jacking the thread
asecretfile
228
#10
  • Aug 6, 2007
  • #10
On my 91 notch the clutch pedal takes about every bit of strength I have to push it. The guy I bought it from said its supposed to be that hard because it is "a heavy duty clutch"
Even still, it shouldnt be that hard to push...in my GT its almost effortless
Anyone else had that problem?
RsStanG1987
569
9
79
Dupont PA
Aug 6, 2007
#11
  • Aug 6, 2007
  • #11
well the clutch decides how stiff the pedal is not the cable.. And a stock mustang will catch about halfway up with the pedal.. 1/2" from the floor is a not properly adjusted cable..
ryan218
Dec 28, 2005
columbus ohio
Aug 6, 2007
#12
  • Aug 6, 2007
  • #12
i guess ill go check that!
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Aug 6, 2007
#13
  • Aug 6, 2007
  • #13
Yes and no. A cable that's starting to bind up, or one that's just poorly designed, will make the pedal a LOT harder to operate. But true, a clutch pedal can only be as soft as the clutch diaphragm will allow it to, by design.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Aug 6, 2007
#14
  • Aug 6, 2007
  • #14
My left leg is twice as strong as my right. Damned King Cobra clutch
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
#15
  • Aug 6, 2007
  • #15
Hey, when you put your KC on yours, was it alot harder to attach the clutch cable to the fork than when you had the stock one on there?
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Aug 6, 2007
#16
  • Aug 6, 2007
  • #16
I don't recall it being any harder? It's been almost 4 years though so who knows. I do know my cable is stretched and i've maxed out the adjustment in the cable, and i believe my clutch is starting to glaze over. Next time i'm going with the Maximum Motorsports cable/firewall adjuster combo and probably a Ram clutch.
Busted07
Nov 15, 2005
#17
  • Aug 6, 2007
  • #17
The reason i ask is it took me both hands and a foot or two to get the cable attached to the fork... its a new KC clutch and a heavy duty fork.
Need a clutch, 1982 Capri RS 5.0 owner, am I allowed to participate?
  • scudzuki
  • Apr 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 7, 2025
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
Clutch cable suggestions
  • sav22rem22
  • May 12, 2023
  • 3 4 5
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 3, 2026
rednotch
