map to maf swap help
mechanicmoore
i have a 88 coupe and have done a maf conversion to it.the thing is that the car will start and run,if you ease into the gas it will rev up fine but if you mat it it will rev to around 3000 rpms then cut back to 2000rpms then go back and forth.i was told to the car should cut off at an idle if you unplug the maf sensor but mine wont it runs better.here is the link that i used to do the swap and have checked all the step twice and the wiring is right. http://www.stangnet.com/tech/maf/massairconversion.html
i have also tried a new eec and maf and didnt change anything.
any help would be great and save what hair i have left.
thanks terry
yes
yes i have done that.i did just as the link said to do.a little extra info:car is a 1988 5.0 with auto trans.i have a A9P ecm part#E9ZF-12A650-CA for a 5.0 with auto trans.after starting the car and finding it not running right i traded out my sons ecm from a 1990 5.0 5 speed ecm A9L.car ran the same.i had the fuel pump relay and VSS wired to the ecm at first.i removed the wires to try to find the problem and it didnt cahnge a thing.i can unplug the MAF and MAP sensor at the same time and the car will still run.i think it is something simple but cant put my finger on it.i have battery voltage at the MAF sensor on pins A(+) and pin B(-).also pins C & D are good to the ecm(checked @ .003 oms and are in the right pins at the ecm.The Signal (-) wire from the MAF meter harness needs an EEC pin which then gets inserted into position #9 of the EEC connector.The Signal (+) wire from the MAF meter harness needs an EEC pin which then gets inserted into position #50 of the EEC connector.The wire currently in position 51 tan/red needs to be moved to position 38. The wire currently in position 11 green/black must be moved to position 32.
all wire points where soldered and heat warpped.cant thing of anything else right now.
The next 2 steps some consider optional but will generate error codes in the EEC. Others have reported stalling problems without the VSS signals. In my opinion it's worth doing if only for piece of mind and no bogus error codes. In preparation for these signals, remove the driver's seat and the driver's side kick panel. There are 3 wires that will need to be added for these signals with EEC pins on one end. I suggest you tie them all together and route them as one cable over to the EEC on the passenger side. I took this opportunity to change the carpet at the same time so I had most of the interior out which made this fairly simple.
i did this also but have undone it to see if it was the prodlem,it was not.car ran the same.
also the check engine light is off,it works cause when you start the car it comes on for a sec then goes off after the car starts.
still have a small bit of hair left.......HELP!!!!!:shrug:
Thanks Terry
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
attachment.php
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
No Change
Ok i unhooked the battery,put all wires back into their pins.hooked everything back up for MAF.changed the MAP to a 1990 one and started the car.It still runs the same way(ease into it and it will rev up----mat it and it will pop and snap go to around 3000 rpms and fall to 1500 to 2000 rpms and go back and forth.checked codes and i get an (11--system OK).Any more ideas.
Thanks Terry
Hey guys i think i have it fixed---on the MAF sensor i had only changed out the box on top due to the BBK cold air going into the fender.Well i took the hole thing off and put a stock one up there and the car is taking the gas now(((WAAHOOO))).
Thanks For The HELP guys.just so ya know it was a C&L housing with a stock box.Dont know why it runs fine now BUT it does and its GOOOOD to me!!!!
