mark viii MAF?
  • Thread starter Thread starter 90StangLX
  • Start date Start date Jun 4, 2006
9
90StangLX
419
Illinois
Jun 4, 2006
  • Jun 4, 2006
Can a 80mm MAF sensor (for 24 lbers) from a '97 mark viii be used on a '90 5.0L? If so, where can the adapter flange be purchased from?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 4, 2006
  • Jun 4, 2006
For the Ford manufactured MAF's, the computer has the calibration for the injector size, not the MAF. The only way to get it to work properly is a wideband O2 sensor & a Tweecer. It would be easier & cheaper to buy an aftermarket 24 lb MAF.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jun 4, 2006
  • Jun 4, 2006
Why don't you just get a MAF housing of a thunderbird supercoupe and use your sensor in it?? The supercoupd housing has a larger opening than the 5.0L. The outside of the housing is the same size. It is undecetable when you pop the hood. You can tell everybody it is stock.!!
vristang
4,933
101
124
Seattle
Jun 4, 2006
  • Jun 4, 2006
JR is right, you will need to change the MAF Transfer and the only way to do that is in the computer. The TwEECer is a good option, as it is well supported and widely used. Ok, that isn't completely true, but it is widely used.
If you don't want to go this route, the best bet for selling it would be through one of the tuner forums. Those guys seem to love the large factory MAFs.
jason
vristang
4,933
101
124
Seattle
Jun 4, 2006
  • Jun 4, 2006
I believe that this would not work for the same reason the 80mm MAF wouldn't work. If the ID of the MAF is different than the stock MAF tube, then changes will need to be made in how the computer interprets the voltage signal from the MAS (the black sensor).
Maybe I misunderstood?
jason
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
