  • SN95 4.6L Mustang Tech
Mass Air cleaning????
  • Thread starter Thread starter NooSlo50h
  • Start date Start date Feb 2, 2006
N
NooSlo50h
9
  • Feb 2, 2006
I read on another thread at a different site that If you have a CAI on your car that has the filter that uses the oil to catch the dirt and dust...like MAC or K&N...that you should clean your Mass Air sencer every now than cause the oil thats on the filter get on that sencer and make the computer read lean or somthing and make the car run rich, and that you should clean the mass air with an electronic cleaner? It even had pictures of him doing it on his 99 cobra.... Is this true or could that possibly ***k your mass air up?????
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Feb 2, 2006
  • Feb 2, 2006
Getting oil from aftermarket air filters on the thin wire sensor inside the MAF can and does happen. 99% of the time it's the owners fault because they do not clean and service their air filter correctly. Will a brand new K&N filter get oil on the sensor? Not likely... but when people wash and re-oil the filter themselves they use too much oil and then this in turn causes the problem.
If you need to clean the MAF sensor wire be sure to use an spray cleaner designed specifically for electronics which leaves no residue.
U.M.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 2, 2006
  • Feb 2, 2006
http://www.bullittarchive.com/1007.htm
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Feb 2, 2006
  • Feb 2, 2006
That's a great write up!
U.M.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 2, 2006
  • Feb 2, 2006
The Bullitt Archive ROCKS! Do you know if the person who created it is a member here?
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Feb 2, 2006
  • Feb 2, 2006
Actually this is the first I've ever heard or seen of it! Pretty cool... Stangnet should start a repository like this.
U.M.
O
OleYellarGT
64
Charlotte, NC
Feb 2, 2006
  • Feb 2, 2006
Yes the Archive does rock, only thing I would add is if you are using a K&N, like I do, then invest a couple of dollars in a paper filter. What you do then is take the K&N out, clean and oil it, and let is sit for a couple of days to allow the oil to soak completely in or drain the excess off. In the mean time, you are still able to drive around with the paper one in. After the couple days, make sure to wipe the excess oil off the rubber ends of the K&N filter, and put it back in.....No problems to report here.
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Feb 2, 2006
  • Feb 2, 2006
Not trying to be an ass here... but if you oil it using the method and instructions included with the filter there's no need to let it sit and soak or drain. If you have to do that you've used too much oil! A little goes a long way and just a drop or two on each pleat is all that's necessary.
U.M.
O
OleYellarGT
64
Charlotte, NC
Feb 2, 2006
  • Feb 2, 2006
still, some tends to get on the rubber ends. Not to mention there are places, like the metal seam, that hold the oil, only to release it at a later date in time. What I am doing just insures there is no oil contamination to the Mass Air.....but what ever trips your trigger
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Cold Air Intake options, is this filter fine or......
  • from6to8
  • Aug 10, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Sep 7, 2024
from6to8
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
