mass air meter size?? 75mm or 80mm
D's 91 stang gt
43
Guys got a 347 eldelbrock performer heads 1.90 2.02" with port and polish 3 angle valve job decent size cam carb style intake with wilson elbow, 42lb injetectors 75mm throttle body etc... need a mass air meter but did'nt know which one to go with I'm lening towards the pro m 80mm but is that to much?? or should I get the 75mm??
The LMAF is a great option, IF you are ready to custom tune the motor with a J3 chip.
This meter will provide great idle (assuming you have a good tuner), and enough airflow to split a stock 302 block.
However,
A custom tune is REQUIRED.
jason
