Medusa Megasquirt.... help lol
Blucifer99
I only understand every 3rd word
Jul 15, 2018
441
30
38
35
Port Mcnicoll Ontario
yeah on his the white wire should be the analog input.
well then he has it wired up backwards.. so ive got him now switching those wires around.. putting the white wire to the O2 output on the DB9 options port connector ontop of the meagsquirt.. should he just leave the blue wire unhooked and taped off.. cause i have no idea where the serial wire would go.. LOL i dont have a AEM
  • Sponsors(?)
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
9,518
5,635
204
30
Hillsborough county
looks like there may be an issue with the MAT sensor wiring or possibly a backfire in the intake, notice in the log the MAT sensor registers a high MAT temp for a few seconds.
The PWM duty upon cranking is too low, the idle spark correction looks too aggressive for the cam. The PWM duty% goes to near 100% to keep the car idling at 825ish.
Just a few things that jump out at me.
Blucifer99
Jul 15, 2018
441
30
38
35
last one long one changed tuned died changed lol restored changed and last few was running decent its really hot out
[/QUOTE
meow what would be causing that spike.?? the afrs are dead on .. could it just be a lil cough maybe since everythings still new.. just breakin in sorta thing? also he had to open his throttle body screw since we adjusted his low idle.. apparently at 825 and a 30% pwm idle valve the car would stall out from not enough air supply.. so he backed it off abit maybe abit to far .. he needs a initial values table built for a auto car too.. hes using a slighty modified version of mine.. also his idle advance was for me to get it decently stable enough to figure out what she wanted for fuel... we had the wrong injector setttings in there lol 95lbs so ves were 93 lol changed that and i belive were at 13.8 at 54 or 56 ve.. The idle adavnce we can always back down try alittle less aggressive curve. see what happens i guess
Blucifer99
Jul 15, 2018
441
30
38
35
That idle valve is acting weird... Going to 100% on startup and back to 34.4 when you hit the throttle then it opens fully to 98.9.. LOL gotta get that straightened out .. somethings up with that valve or the wiring..
Blucifer99
Jul 15, 2018
441
30
38
35
how is it coming along? you should probably be close to a point where a tuning class would get you where you are doing it all by yourself. When i have a chance i will look at the datalog and tell you what i think.
well so far the cars idling and running fine.. starts up good.. holds a steady idle.. but i did dumb down his idle advance curve alot. since his cars auto it dont need that aggressive of a curve.. also i added a :poo:ton fuel to his loaded part of his VE table.. car was abit lean he was sayin,, but not by much.. target 15.0- actual afr 15.8.. so its in range.. but now his idle valve is acting funny.. fully open on start up until you burp the gas and it plains out to where it should be 34.4% then slowly climbs wide open to 98%... no idea whats causing that.. it was working perfectly before.
Jun 15, 2019
64
46
lake george, ny
im just chasing a bunch of dumb issues,,,, ill deff need some advanced tuning when i get into boost,,, may take some time to chase charge issue,,,, thnx for the feedback
