- Jul 7, 2005
- 1,563
- 1,110
- 164
That’s the next move is slimming down the needle. I’m going to make it smaller in the morning.
They’re pretty straightforward. Power, ground, and a switched 12v is all it takes. You can tie it into the wiring so when you open the door it turns on but I didn’t bother with that.I NEED ONE OF THESE! How plug and play are they?
Everything above is correct in only needing (3) main wires of batter, ground, and ignition. The dash bezel is also a direct replacement of the factory unit, so no need for fitment to install it in your vehicle.I NEED ONE OF THESE! How plug and play are they?
Yessir. With ms2 we use GPS based speed and odometer. With ms3 (stinger pimpx ect ) if you have the vss or a speed sensor installed we can help you make an odometer and even set the start mileageThese are pretty cool.
As much as a purist as I am, i wouldn't mind something like this in the future. I assume the odometer can be programmed as needed? Keeping record of my mileage is important to me (even if i'll never sell the car).
That is no problem with the customization of the dashboard. The logo is just a background image that can be removed and then you can change the gauge background color and dashboard background to anything that you want.I'd like something similar to this setup but less 'busy'. No emblems, logos, etc...
This would look best with a flat black background.
I know... I'm boring.
Just as an example, I really like this kind of setup:
Question: With the hardware/software that you have, how much flexibility do you have to say... draw your own gauges and bezels?
Also: Do you have the abilty to rotate the gauge images so that all the needles point straight up and down at cruise? (Race style)
I ask mostly out of curiosity.That is no problem with the customization of the dashboard. The logo is just a background image that can be removed and then you can change the gauge background color and dashboard background to anything that you want.
I try to have the gauges point straight up too just like you want by tweaking the min and max readings.
I can always whip something up for you if you want
Huge step down IMO.Yes, we have a new page for new instructions and additional wiring diagrams as wellWill you be updating the instructions to reflect how to install the pro dash with the blinkers high beams and fuel level?
I love your page and docs. I know what it takes to get to something that looks that good.Yes, we have a new page for new instructions and additional wiring diagrams as well
DD-EFI Technical Resources
Digital Dash EFI repository of technical resources of products including Quickstart Guides, Complete Manuals, Videos and more. We strive to provide the best Megasquirt Digital Dash on the market with the best customer service and documentation.dd-efi.com
