We got the block and rotating assy back this week. Just had to break the glaze on the cylinders and we had the rotating assy balanced. We got forged pistons and rods for the beast. Got a new oil pump and all the usual bottom end stuff. Had the crank journals polished. We had the heads cleaned up and did a little bowl porting on them. Valve springs checked ok so we will reuse them. We replaced the worn out clutch cable. I pulled the rear end apart and rebuilt the Trac-loc and installed new seals. The gears looked great and laid down a good pattern. We're debating getting aftermarket axles as i have had a few hair raising experiences on the track with stockers. Had a stocker come out of the axle housing and did an immediate right towards the wall. Luckily i got it stopped in time before i hit the wall. I did wipe out some of the timing equip and a cone though. The only thing we are not sure of is the camshaft, we have a few grinds running through our minds. What grinds have you folks had good luck with. This will be an occasional track car. it is a 5sp. Getting excited to kick the wifes 95 GT's butt.
