mother of god i think the steering took a crap
If you decide to change the steering rack, here's some tips...
The two inner tie rod ends are usually what wears out, and at $45 each, it's better to get a replacement rack assembly since they are part of the package. The rack is about $100 + a $40 refundable core charge, which you get back when you return the old rack. Be sure to ask for the GT or high performance rack, it has fewer turns lock to lock than the standard rack.
The flex coupling for the steering shaft needs to be disconnected before you can get the rack out. You should disassemble the coupling by undoing the 2 bolts that hold it together. The lower part of the coupling will then come out with the rack, and can easily be removed.
The tie rod ends can be removed with a tool that looks like a giant "pickle fork", it's less than $8, or some stores will rent/loan one. Remove the cotter pin & nut on the tie end, stick the tool between the rod end and the arm it connects and hammer away. The bigger the hammer, the easier it comes apart.
Remove the two bolts that bolt the rack assembly to the frame and then pull the rack down. Get a catch pan to dump the fluid in when you disconnect the hydraulic lines.
To change the tie rod ends, do them one at a time. Loosen the jam nut 1/4 turn, then unscrew the tie rod end from the rack. Turn the jam nut back 1/4 turn to return it to its original position. With the tie rod end removed, use a machinist square to measure the distance between the end of the threaded rod and the jam nut. Sit the bottom of the square against the end of the threaded rod, and the end of the blade of the square against the jam nut. Duplicate the measurement on the new rack and then install the tie rod end and tighten the jam nut. Then do the other side: the front end will need aligning , but the toe in will be close enough to the setting of the original rack to drive.
Buy several extra quarts of fluid to run through the system to flush it when you change the rack. Fill the pump up, start the car, and turn the wheels lock to lock to bleed the air out. Then stop the engine, disconnect the low pressure hose (the one that is secured with a hose clamp) and drain the pump. Re-connect, refill and do it several more times or until the fluid looks clear and not burnt or black.
stang2841 said:
i would want a performance one kinda has to be a power steering
im a big boy tho but a manual rack and pinion i heard is a nightmare
:rolleyes: c'mon man.. I've had a flaming river quick ratio manual rack in my car for about 2 years & I like it way better than when I had power steering. It's not as touchy as the power steering. Of course I'm running skinnies so that helped out a lot, but even before it was only a b?tch when the car wasn't moving.. If you ask me, it's a no brainer.. I replaced 2 power steering racks before I had enough of it.. plus you'll free up some hp & room under the hood :nice:
Power steering pumps screech when the wheel is turned and they have no fluid.
If you cannot keep fluid in the pump, BYPASS IT. Otherwise it will eventually seize and fall apart at your inconvenience, leaving you with no cooling or charging systems.
How would you guys rate a manual rack on a scale of 1 to 10, 1 being a power rack with pump not working and 10 being functional power steering?
Because if it is even halfway as bad as a failed pump, which I have been driving with for the last month (damned Dodge), there is absolutely no way I would go with a manual rack on a real street car. I can handle it fine, but the CONSTANT effort to keep my car on course, and the embarassment of trying to park, is really wearing me down.
