motor junk
  • Thread starter Thread starter 93lxmustang
  • Start date Start date May 17, 2006
9
93lxmustang
10
  • May 17, 2006
So the other day i get home from school and hear an exhaust leak comming from the headers so i pop the hood and the motor is shaking like crazy so i figure somethign is wrong with the motor...so i call my dad outside and we look into it and the motor is knocking and making all sorts of noises............comes to be the motor is junk had 117,000 miles on it and was running a paxton blower......Just pulled the motor 2day and sent it out to the machine shop. going with a 306 with ported heads 9:1 or 10:1 compression ratio with new 42lb injectors, 255 lph fuel pump, and hooking up the dry shot of NOS. Should have motor back and up and running by the end of this month. cant wait till see what it puts down for numbers on the dyno with a built motor-sc-and nos. not sure what shot to run on the nos kit?? any ideas?? dotn want to kill the motor to bad since it is brand new.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 17, 2006
  • May 17, 2006
if you are going to run a blower don't go above 9 to 1 compression ratio. a 8.5 to one would be better.
9
93lxmustang
10
  • May 17, 2006
Was wondering if you knew what the stock compression on a 5.0 motor is??
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 17, 2006
  • May 17, 2006
i believe they are 8.5 to 1
9
93lxmustang
10
  • May 17, 2006
So the stock compression would be all right while running a sc??
9
93lxmustang
10
  • May 17, 2006
Today my dad and I pulled the motor-driveshaft-tranny-and exhaust and stripped the motor done into pieces in 5hours. We have found out that the rods and main bearing are whipped out and the crank needs to be turned while the cam-b-heads-and pistons are completely fine.
Euphoric306
905
  • May 18, 2006
93lxmustang said:
So the stock compression would be better while running a sc and nitrous??
fix.T
pistonhead351
flim hunter
May 1, 2005
75
  • May 18, 2006
you said you already had the motor off to the machine shop in the first post??? sounds fishy, oh well good luck with it.
larrendeuce
649
Southern NJ
May 18, 2006
  • May 18, 2006
stock compression with stock heads and gaskets is 9 to 1.
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
J
  • JRC99
  • Apr 19, 2025
2K
JRC99
J
