motor junk
93lxmustang
10
So the other day i get home from school and hear an exhaust leak comming from the headers so i pop the hood and the motor is shaking like crazy so i figure somethign is wrong with the motor...so i call my dad outside and we look into it and the motor is knocking and making all sorts of noises............comes to be the motor is junk had 117,000 miles on it and was running a paxton blower......Just pulled the motor 2day and sent it out to the machine shop. going with a 306 with ported heads 9:1 or 10:1 compression ratio with new 42lb injectors, 255 lph fuel pump, and hooking up the dry shot of NOS. Should have motor back and up and running by the end of this month. cant wait till see what it puts down for numbers on the dyno with a built motor-sc-and nos. not sure what shot to run on the nos kit?? any ideas?? dotn want to kill the motor to bad since it is brand new.
Today my dad and I pulled the motor-driveshaft-tranny-and exhaust and stripped the motor done into pieces in 5hours. We have found out that the rods and main bearing are whipped out and the crank needs to be turned while the cam-block-heads-and pistons are completely fine.
you said you already had the motor off to the machine shop in the first post???:shrug: sounds fishy, oh well good luck with it.
