Engine Multiple engine codes
TTSaleen05
115
33
Louisiana
Fixed the water pump seal, no change in idle...still surging and when i First cranked i assembled it, I was able to rev it without it breaking up. Now it’s back to the bad idle and the breaking up. help
  • Sponsors(?)
StratTone
66
9
18
42
Are you sure you have a check engine bulb that will light? Worth checking. It sure acts like it doesn't know what to do with information it's being given. I'm leaning towards computer, CEL blown and there is codes.
TTSaleen05
115
33
Louisiana
Yea, it illuminated before the tear down to change the timing chain. I tested the alternator and it was bad as well so I replaced it. Put it all together and still the same symptoms. The check engine light has not illuminated since I cranked it back this morning. #mustangfromhell
General karthief
Mod Dude
Aug 25, 2016
17,326
5,594
193
polk county florida
Have you done the surging idle checklist? If so do it again.
one thing I think I noticed was the timing light did not have a consistent flash like the ignition was cutting spark.
TTSaleen05
115
33
Louisiana
I will do the surging idle checklist first thing tomorrow, if that is the case with the timing light not being consistent, what would cause that? The plugs are new, the wires are new and I pulled the coil and distributor from a known running car.
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,441
2,873
234
74
Dublin GA
lowendmac.com
That leaves the TFI, wiring, and coil as possible culprits. What sort of codes are you getting while the engine is running?
TTSaleen05
115
33
Louisiana
None, the check engine light wasn’t illuminated while i had it idling. But It it was on previously before I replaced the chain
General karthief
Mod Dude
Aug 25, 2016
17,326
5,594
193
polk county florida
The computer has little to do with 'getting it above 1k rpm '. It is only as good as the information it is given. Check your cap and rotor for cracks and buildup on the contacts, make sure the distributor does not have excessive side play, the checklist should cover everything else.
Blown88GT
2,082
484
134
Palm Beach Gardens, FL
Well, assembled the car just to find out the water pump is leaking from the bottom ughhh...I must’ve didn’t seal it properly
As I was reassembling after the timing chain cover & water pump, the PS pump went, the seals were shot. Now having issues with the old supercharger automatic belt tensioner. My machinist is working on it tonight.
  • Angry
Reactions: General karthief
TTSaleen05
115
33
Louisiana
Well pulled the codes again:
12
21
42
92
33
18
Im able to rev it at full throttle, any thing less than that it breaks up. Still surging/cammed idle. Smoking as well, Black on startup then blueish when idling and revving. Fuel pressure is steady and doesn’t drop off...new plugs,wires...swapped distributor from a good running 5.0(my dads 89 grand marquis) same exact codes #mustangfromhell
Thread starter Similar threads Forum Replies Date
justinc87 Multiple Errors - 05 4.0 2005 - 2009 Specific Tech 1
K Engine Misfire in multiple cylinders SN95 V6 Mustang Tech 2
splinterddt Multiple Misfire Codes 2005 - 2014 S-197 Mustang -General/Talk- 68
T Hi everyone, I joined Stangnet because I have a 1996 Mustang with multiple problems that I would like to repair 1996 - 2004 SN95 Mustang -General/Talk- 1
M Multiple codes popped up on my 2010 v6 mustang HELP The Welcome Wagon 1
O 04' GT. Multiple advice bullets needed 1996 - 2004 SN95 Mustang -General/Talk- 1
W New Member, Multiple Mustang Owner, Autocross Ambassador The Welcome Wagon 0
ngiotta Electrical 95 Cobra - Multiple electrical issues 1994 - 1995 Specific Tech 3
G Multiple Codes - Bad ECM? 2005 - 2014 S-197 Mustang -General/Talk- 4
noiseguy 2013 V6 throttle body - Multiple failures 2010 - 2014 Specific Tech 3
A Electrical Multiple PCM problems Fox 5.0 Mustang Tech 8
M Electrical 02 GT - Multiple Electrical Issues SN95 4.6L Mustang Tech 9
N Wits End Multiple Misfire Codes 1996 - 2004 SN95 Mustang -General/Talk- 9
D New To Boards. Multiple Stang Owner With Lots Of ?????? The Welcome Wagon 2
MYTURBO Multiple Issues.. Fox 5.0 Mustang Tech 28
G Multiple Mustang Crashes - Mustang Week 2014 1996 - 2004 SN95 Mustang -General/Talk- 4
E First Post And Multiple Questions. 1994 - 1995 Specific Tech 9
805mustang Having Sensor Value Issues On Multiple Temp Sensors! Does Anyone Have A Wiring Diagram????? 2005 - 2009 Specific Tech 0
D '92 Mustang - Irregular Idle - Multiple Starts Fox 5.0 Mustang Tech 1
7 Multiple Issues With 93 Mustang Fox 5.0 Mustang Tech 42
9 multiple mis-fire problem 2.3L (N/A & Turbo) Tech 2
9 multiple mis-fire problem 2.3L (N/A & Turbo) Tech 0
Silvestris Multiple misfires, I need some help SN95 4.6L Mustang Tech 6
tjsteeda Steeda commits to order multiple 2013 Mustangs to support Ford performance customers! 2005 - 2014 S-197 Mustang -General/Talk- 3
A Multiple Cobra Parts! 42lb injectors inside also. Engine and Power Adder Parts 6
boostfrk Multiple Codes - Maybe single source of problem? Fox 5.0 Mustang Tech 15
D FS: Multiple BNIB 01-04 mustang GT roush supercharger Engine and Power Adder Parts 1
Legacy5.0 Multiple Answer Question. Fox 5.0 Mustang Tech 7
F 2002 gt not running??? had multiple missfires not running!! SN95 4.6L Mustang Tech 1
eschlenz Wiring Multiple Gauges (cleanly) 1994 - 1995 Specific Tech 10
slick35thgt Multiple Personalities of My Car... 1996 - 2004 SN95 Mustang -General/Talk- 10
2 Multiple restoration questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
stangman16 multiple codes - cannot figure it out.... Fox 5.0 Mustang Tech 7
1992 2.3LX Any Programmers for Multiple Vehicles??? 1996 - 2004 SN95 Mustang -General/Talk- 2
67coupe Hanging idle returns after cleaning 10pin multiple times!!! Fox 5.0 Mustang Tech 16
95_SVT-wingman multiple trips to the CA smog station 1994 - 1995 Specific Tech 0
J multiple codes, need help Fox 5.0 Mustang Tech 10
FoxbodyGurl 93--- Multiple Problems Please Help! 2.3L (N/A & Turbo) Tech 4
G Help - Search - Requiring Multiple Words 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
tmoneyballin Completed multiple mods and have a weird idle problem... SN95 4.6L Mustang Tech 5
poneypower89 a few multiple questions... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
mustangjoe87 Multiple monitors? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
N Who knows anything about torque multiplication? 1994 - 1995 Specific Tech 4
S What is the calculation for torque multiplication? Classic Mustang Specific Tech 9
Dusstbuster Multiple Questions (what to do this year) SN95 4.6L Mustang Tech 1
Foxfan88 converter torque multiplication... Fox 5.0 Mustang Tech 1
crazypete Multiple sets of cats: two 3-ways inline. Any benefit Fox 5.0 Mustang Tech 0
N MSD tach output for multiple devices? 1994 - 1995 Specific Tech 0
AEinPA 66 Coupe - Multiple Questions Classic Mustang Specific Tech 3
Route666 Valve Covers and multiple coils Classic Mustang Specific Tech 7
