ras50gt said:What pistons did you get? What was the final price?
89white50 said:if you put 302 puts in/on, you will get 302 power.
Get a set of 180+cc heads, a descent cam (if you have to go OTS the XE274HR's seem to make power), a 70mm throttle body and an 80mm MAF. prob 30-36lbers depending on fuel pressure.
I will be using a set of 180cc Protoplines heads, i suggest something like those if you want a good deal (same as RHS, and flow better than advertised out of th box). Has anyone seen the picture of RHS heads on their website? in most cases you can clearly see the Pro Topline logo and smoking wheel in the corner. amazing...
68keyblr said:Whoah! What intake are you using? What freeway mileage do you get with that combo?
Edit: I'm a moron, just saw the Systemax II intake...
89white50 said:oh and if your going to spend nearly 300 on a cam, you might as well go custom, more power and driveability for prob 50 bucks more.
and I had the money I was just being cheap! check uot my sig this should be plenty for what you need and I get 20MPG when I drive 65-70 (2300RPM 3:55 gears)cdog301 said:Going budget will bite you in your A$$ I bought cheap rocker arms and one siezed up the I fixed that then I broke a rocker stud it cost me so much more money than if I ahd used the right parts initiallyand I had the money I was just being cheap! check uot my sig this should be plenty for what you need and I get 20MPG when I drive 65-70 (2300RPM 3:55 gears)
Have you ever bought a custom cam? It will end up being a HELL of alot more than 350 dollars! Jay allens camshafts are around 550!89white50 said:oh and if your going to spend nearly 300 on a cam, you might as well go custom, more power and driveability for prob 50 bucks more.
hi, i asked the same question with my combo (signature) and some person answer me arround 350 HP to the wheel thats too low...retro50 said:Put on a set of A.F.R. 185's, Comp XE-274 or XE- 282 H.R., Systemmax intake, 75 TB, 30LB Injectors and a 75-80 Mass Air Meter. Should pull over 400 h.p. to the rear tire easily. With all the parts you originally listed maybe 310 at the wheels and that would be stretching it.
i whant over 400Lxstang306 said:68keyblr sound like a good street motor if u wanting to get MPG and keep ur power drop a turbo on it there all kind of kits out there all over ebay CHEAP. or if u good with a welder and piping make a kit.
