I had the intial at about 10, but now im not sure what it is because i adjusted it so i would get the best vacuum about 18 inches at idle, and when i put it in gear it drops to about 14 and the needle is kinda shaky. I dont think it is running rich, but i will check my plugs anyways and that all cylinders are firing. Also will check for vacuum leaks (around the base of the carb and intake front and back, the rpms should increase if there is a leak, right?) Ive been told that 500cfm is plenty. The taller deck height is interesting, i didnt know that and the machine shop didnt say anything about it. The heads are 1966 54cc chamber heads.
The engine does feel flat like 390Fe said, i thought i installed the cam/timing chain properly, but maybe i didnt. The cam has a standard 302 firing order. I can do a compression check and get back to you guys with the results but i dont have a leak down tester, is it really important to check that also? The carb was
kinda tuned with a vacuum guage, tach and what some people on here told me to do.
The cam specs are:
Cam Lift, Int-.281, Exh-.296
Valve lift, Int-.450, Exh-.474
Lobe ctr, Int-102, Exh-116
Adv. Duration, 280 Int, 289 Exh.
.050 Duration, 204 Int, 214 Exh.
Its a pretty small cam so i dont see why i would be having problems with it
I had a Pertronix Ignitor with stock plug gap. The engine does idle, but not very well when cold, but gets better when warmed up. Rpm at idle is about 800+-, 18 inces of vacuum at idle (with timing probably way advanced) and 14 with a shaky needle in gear.
I hope this is enough info
I will check the things you guys mentioned and get back to you. Thanks
