Max Power said:Maybe you need to find true TDC and see if your harmonic is lined up to 0 degrees.
I did do that, i stuck my finger over the #1 plug hole and cranked the engine till if puffed off my finger, then i stuck a small wooden dowel into the hole and turned the engine over by hand till it just barely started to go back down, then i turned it backwards to tdc and the balancer was pretty dang close. Is this not an exceptable way of finding tdc for #1?
( i know its kinda hokey, but i dont see why it wouldnt work) I also dont understand how i could of installed the cam/timing set wrong. I lined up the two marks on the gears and both gears only had one keyway, so it could only go on one way. I think the reason my engine is so gutless is the piston choice/cam combination. Also, (shhhh) I have MS Office on a disk that I might be able to share for a..ahem...trial period, if you really need to get Excel....ahem
If you could do that for me, that would be great
Much thanks
And Crush, I'd also go back to your machinst that recommended those pistons to you and give him a swift kick in the pants, he ain't got a clue as to what a Ford needs.
