My next project , a 428 build!
Just got it back ,freshly honed ,and balanced and ready to build except my rings wont be here untill Thursday!
Reactions: DadLife0724
My rings made it in today !
Got the cam in ,double roller chain is on , pistons in ,heads torqued but the intake is just setting in place because I need the distributor to set the intake.
I need the distributor ,cobra oil pan ,cobra valve covers and a high volume melling oil pump . The water pump is supposed to be here tonight . Also need hooked headers ,all the very expensive stuff!
It's always amazed me how long the front crankshaft is coming out of the front of the timing cover. The closest thing that I'll have to a 428 is my '68 390.
I have the cast iron heads, but my brain is doing cost analysis of the cost of aluminum vs how many mpgs more could I could get with them.
Driving a big block vs small block, '67 or '68 Mustang, you can really tell the weight difference.
Pic below of my short block. I've kept up with the special pulleys and brackets.
Also, the 2nd pic is of a guy in California that fuel injected his 428 FE with some aftermarket pieces and a 1998 FoMoCo pcm and modified harness. It's pretty cool.
This thing is badazz!
Put the oil pan on ,its just to keep out dirt for now . I hsd an old set of Mickey Thompson valve covers ,they cleaned up decent enough to keep dirt out . I am about as far as I can go for a while now . Next week some time I am going to try to build a new start up stand for it ,but this one will be set up to change motor mounts .
I ordered my oil pan yesterday from Branda ,this morning I get a call asking if I wanted 1 or two? I had clicked two by accident ,it was Carl asking if I had messed up my order ,and yes I did ! Most shops would probably just sent both out but Branda has a bit more integrity! I haven't ordered from branda from the last car i built many years ago and it was Carl I dealt with then ,its good to see that some of the same same people are still at it !
Dug out a bell housing ,flex plate ,backing plate and starter ,dont know if a flex plate will work with a manual bell housing but I guess I will find out. I have a standard fly wheel here some where just have to find it .
Oil pan and distributor are supposed to be here Friday and then I will build a new start up stand ,it will probably sit on it for quite a while!
Reactions: LILCBRA
