I like everything but the dowpipe(the blocking acess to the spark plugs wouldnt really bother me) it looks like its touching the valve cover....my 20g turbo on my neon consistently has EGTs of 1600 degrees after a hard run....thats a lot of heat to be transfering to the valve cover....if it were an aluminum cover it would melt....steel, the flange for the gasket may warp...if I were you I would definately wrap the downpipe too...I'm planning twin turbo for mine...using a pair of stock cast iron manifolds(probably ported) so I have eneough room to run downpipes underneath them, anyway, looks like good work, I'm always interested in turbo systems....another thing you may want to consider is getting an aluminum manifold with bosses for fuel injectors for better effeciency(or drill your own injector holes into the stocker) I also notice you are still using the distributor...why? I use MegaSquirt on my turbo neon and was actually running Ford EDIS-4 with an escort module and a 4.6L trigger wheel mounted to my crank pulley, being able to adjust spark timing through megatune is priceless
