I am going to put Magnum 500 wheels on my Mach. I am going to use The Granada front brake upgade and have my rear axles re-drilled. My question is what size should I go with?
15x6" with 4" back space.
15x7" with 4 1/4" back space.
15x8" with 4 1/2" back space.
I have 225/50/15 BFG drag radials for the rear and I was thinking about 205/55/15 T/A's for the front (both are 23.9" tall). I was thinking about the 15X6" for the front and 15X7" for the rear. Do you guys think I could get away with the 15X7" front and rear?? Keep in mind I have track day and solo II plans so, I don't want any rubbing during extreme handling conditions. I already have a problem with pre-mature rear tire wear, I don't need front
I also plan to lower the car by using 2" blocks in the rear and cutting a coil or so off the front. (I have new V8 A/c coil springs in the front and it sits pretty high). Bad photo shop of what it should look like. I can't wait! I have 205/60/13's on the front and 235/50/13's on the rear now. The really short tires and the 4x4 stance combine to make it look pretty gay
at the time). Thanks for the help guys 15x7's with 225/50/15's all round then
