Can you guys recommend a good roller cam for a 351w with a wiend stealth intake and a set of the early powerheads?
I've run Comp Xtreme 268 cam on two engine combinations with great success and would get one again except it doesn't look like they have a roller cam with the same duration lift as that. I understand the rollers change things up a little, but I have no idea what I should be looking for. The Ford cams advertise equal intake and exhaust duration and lift (228/228 .484/.484) I thought you wanted more exhaust duration and lift than you had at the intake. Am I wrong? Does that change for a roller engine?
I also need to ask about my flywheel, it's used off a 90 5.0. I got it when I bought a T5 years ago. I had the balance matched to my current engine, and slapped it on. No problems were had with the starter, so I assume that somehow it worked with my 73 auto starter. My car's a 73 BTW. I've been looking for a replacement and it looks like for the 351w I need a 28oz weighted one, but how many teeth?
Oh and what length push rods will I need for that roller cam?I'm slappin in a new shortblock.
