  • SN95 4.6L Mustang Tech
Need a little HELP with Timing
  • Thread starter Thread starter 98bluevert
  • Start date Start date Feb 21, 2007
98bluevert
130
Mattoon, IL
Feb 21, 2007
  • Feb 21, 2007
Ok so i have a 98 GT that i was replacing the cams in and i was using the Anderson Tool to do it but my friend that was holding it let it drop and i think the chain has now skiped a tooth.
how do i go about degreeing the cams?
I have rotated the engine by hand but it stops a little was through a turn so i figure the valve is hitting the piston.
Anyone that could give me advise or links through searches would be helpful. I'm am just not finding or searching the right words to find what i need.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Feb 21, 2007
  • Feb 21, 2007
do you have the front cover removed???
98bluevert
130
Mattoon, IL
Feb 21, 2007
  • Feb 21, 2007
No i got ticked off and left everthing where it was. That will be the next step.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Feb 21, 2007
  • Feb 21, 2007
ok once you get that done the crank and cam sprokets should have a mark on them and you put the one link in the chain that is of different color on them and then it should be fairly close to being straight up
98bluevert
130
Mattoon, IL
Feb 21, 2007
  • Feb 21, 2007
ok so i don't have to go get a degree wheel and dial indicator and all that stuff, just a harmonic balancer puller and replacer then line the different links up.
Are the links painted or are the a different metal like brass or something?
98bluevert
130
Mattoon, IL
Feb 22, 2007
  • Feb 22, 2007
***BUMP***
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Feb 22, 2007
  • Feb 22, 2007
Is this the stock shortblock? What are the specs on the cams? Need some more info, then I can help.
98bluevert
130
Mattoon, IL
Feb 22, 2007
  • Feb 22, 2007
Stock 1998 shortblock non powered pos, stock heads. Just changing the cams out with PI cams and updated PI intake.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Feb 22, 2007
  • Feb 22, 2007
If you cannot hand turn the crank at least 2 revolutions without hitting something, you are probably having PTV contact.
Decent writeup. I don't have time to type everything:
PI Cam Swap
98bluevert
130
Mattoon, IL
Feb 22, 2007
#10
  • Feb 22, 2007
  • #10
thanks thats what i needed, a link or info is just right, i figured i have ptv contact, just needed more info on timing the cams with the crank, but found out that there are two links of different color that i am suppose to match up on the keyway and the cam gear
98bluevert
130
Mattoon, IL
Feb 22, 2007
#11
  • Feb 22, 2007
  • #11
link didn't work just stared out the name of the website
Tim2002GT
635
Tulsa, Oklahoma
Feb 22, 2007
#12
  • Feb 22, 2007
  • #12
Just delete the stars in the web address and replace with modular depot.
forum155pl
520
the 509
Feb 22, 2007
#13
  • Feb 22, 2007
  • #13
if your chain doesnt have markings, you can mark a random link with white out or something that wont rub off easy... then hold that link with your thumb and fingure and hold it up.. the link at the very bottom is where the other dab of white out goes.. now you gots yourself some new links....
Timing is a pain in the butt when your doing it for a first time... just take your time and check over everything many times...
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Feb 22, 2007
#14
  • Feb 22, 2007
  • #14
Why does that happen, do you know? That's very strange.
Tim2002GT
635
Tulsa, Oklahoma
Feb 22, 2007
#15
  • Feb 22, 2007
  • #15
I think it is because of some sort of "politics" between the two sites!
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Feb 22, 2007
#16
  • Feb 22, 2007
  • #16
Like forum155pl mentioned, the factory hypoid chains have copper end links. It's hard to tell them apart from the rest of the links sometimes, especially if the chain is dirty. Once you find them, it's a good idea to mark them.
That's weird about the link being "bleeped" out. I guess maybe it's for legal reasons.
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
R
Need a little help identifying this plug
  • redlineracing1328
  • Oct 7, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 8, 2025
revhead347
