I have a question that strikes at the very heart of how the fuel injector and ECM work together, and would like to hear from anyone who knows this relationship between parts very well.
I'll give you my theory, and you tell me where the flaws are:
If 19# injectors run 302 cubic inches (everything stock) with an SD EFI system, will simply changing to larger injectors trick that SD system into thinking it is running 302 cubes, when I have actually substituted 351 cubes in it's place?
The only reason the SD won't run more cubes is the preprogrammed fuel curve is optimized for 302 cubes, so a bone stock 351 (or even 408) should require more fuel that the "dumb" (as in blind to change) SD system would not recognize... Correct?
So if I divide 19# by 302 cubes, then multiply that number by the new cubes, which is 23# for 351 cubes, if everything is left stock but the displacement, will the ECM supply the extra fuel for the extra displacement without protesting? The 351 would need a bit more fuel, but the timing and fuel mapping should be perfect so long as the extra fuel delivery is there... ???
I want to keep an SD sytem while upping my cubic inches if you haven't guessed. I just want more cubes, I won't be making other changes such as fancy heads or big cam. So does my theory hold water?
Thanks!
Dave
Thanks!
Dave
